Progress on my p3steel build. I was lucky enough to borrow a 3d printer from the local library, and used the opportunity to print out a new set of parts.
Toolson http://www.thingiverse.com/thing:1054909 has a very nice set of parts that upgrade to a very stable machine. I did my own modifications to the front and back set of the y-axis plates. The original pieces could not withstand the tensioning of the y belt. For this reason I do not recommend this version of the p3steel.
I am using my own version of compact extruder for j-head (also on thingiverse). I also have my own version of the y-axis bearing clamps (eventually I will replace the plate with an aluminum one).
I also modified the extruder gears for added strength on the small gear nut trap, as well as higher tolerance (the gears are the hardest thing to print, I went through 4x 10 hour prints until I got an acceptable set).
The printer is extremely heavy. It has taken me a long time to get to this point of assembly, and a lot of modifications to parts, drilling, reaming, cutting, etc. I would put the assembly level at expert. You can still assemble this printer if you are new, but it will not perform to its full potential.
i have used x ends from hephestos,they have belt tensioner. For x axis best looking parts are from latest version from jo prusa,it looks great :)
