I would like to use a proximity sensor for helping me with bed levelling. It is a LJ18A3-5-Z/AX it is a normally closed NPN sensor.
I am driving it with the same 12 volt as the smoothie board. Can I tie the sense line directly to pin 43 (Y max) with a diode in between to prevent reverse current from harming the IC1, or do I have to do something else.
In the NC position I measure 0v (ground) on the sense line, that sounds right because it will be sinking to ground. When the sensor fires I measure 12v. I guess it must be floating to a high. What else may I have to do in the configuration file to make this work?
I was thinking a little more on this and assume now that I could use a 3.3 v zener diode clamped to the sense line. That way it will never go over that amount. Am I thinking right?
