Question about engraving mirrors. I picked up some nice 1’x1’, clearance so not spec ) mirror just to play with. I did some engraving and it etched the glass but also left a gold colored film behind. This flim is hard and doesn’t come off. I tried going faster but it left the black on the back also. I also set the machine on cut to see and it removed everything 30mm and 8ma.
How can I engraved using vectors? I seen a YouTube a guy doing this but no explanation or tips.
I actually tested this very early on when I got the K40.
I used a 2 methods to test.
1st method, I converted the image to vector (using Illustrator Live Trace feature). Then, from there I created a patterned fill of 0.5 x 0.5 mm circles). This method worked, however it vibrated the machine out of alignment. So, technically no good as you will constantly have to realign your mirrors.
2nd method, I did the same image conversion, but instead of using patterned fill of circles, I used a patterned fill of lines, spaced very close together. It worked perfectly & didn’t vibrate the machine. However, as you see in that video, the effect is slightly different. Mine, I didn’t consider finalising the “mock engrave” with a cut around the edge of the object, so I had jagged edges that looked pixelated. However, with a final cut around the edge, would work perfectly.
Basically, all you need to consider is low power/high speed cut, in order to do this, but convert your images to use a series of lines instead of raster pixels. Never use the engrave option, but use the cut option instead.
@I_Laser I have been curious about that also, but it seems that people who have engraved anodized aluminium haven’t had any problems as yet. Personally I’d imagine the beam reflecting off the object would lose some focus as it passes back through the lens in the wrong direction. I may be wrong however, just my thoughts.
Depends on the design software you use. As I use Adobe Illustrator, it was very easy for me to create a Pattern Swatch of lines that were spaced 0.5mm apart. At the time, I was unaware of limitations of the machine & the CorelLaser software, so I would revise the process now.
I would create lines of 0.01mm thickness (because CorelLaser cuts anything thicker twice, once on each side of the line). I would then space them 0.01mm apart. As the kerf (or width of the laser beam) is very small (~1mm for 100mm x 100mm square), this should be enough. Actually, I can go do a test shortly to make sure.
I would say the entire process would take all of about 1 minute to create the pattern swatch & apply it to all the shapes. Also, I would create 2 patterns. One with horizontal lines spaced apart vertically & one with vertical lines spaced apart horizontally. I will do that in my test to show you the difference in result (I am unsure what difference it will make, but it may make some). Also you could do angular lines, or even concentric shapes (e.g. one circle inside another circle inside another circle etc etc until you reach minimum size). I wouldn’t really recommend the concentric shapes as cutting extremely small shapes is problematic (i.e. it makes horrible sounding noises in the machine, thus the smallest I have been able to cut with no real problem is 1mm x 1mm circle).
I will do up some examples/tests shortly & post some photos to show you the results.
Turns out I mustnt have done a pattern fill, because Corel interprets that as either solid black or solid white. I must have done something else in past. I will figure it out & let you know.
Thank you Y.S. taking the time to help. Ill see what I can come up with as well. Now that you pointed out what I should be doing. Im going to try it in Vcarve pro, something simple.
@giavonni_palombo I will give it a go again some other time when I’ve got some spare time. I will try do something complex also, to see if it is doable. Simple objects are easy enough, as you said, but complex could prove to be problematic.
