Question about PWM pins.
Which MOSFET pins support PWM? On the documentation pictures it only mentions PWM for pin 2.4 and 2.5 while under the Switch module in the documentation it suggests PWM for pin 2.7.
Similarly can I use 1.18 to 1.21 (led1-led4) for PWM after I set #leds_disable = true in the firmware? If so what voltage do the pins give at 255? 3.3v or 5v?
Figured it out. For future reference, the answers are yes, and 3.3v.
