Question Daniel.. does the library configure SPI on the Zero or do I need
Question Daniel… does the library configure SPI on the Zero or do I need to implement that and provide your code with the pins I’ve opted to use?
I haven’t gotten around to implementing hardware SPI support for the zero yet - so you can use any pair of pins that you want to get bit-bang’d output.
