Question for those who are using cable chains...Where and how did you mount the
Question for those who are using cable chains…Where and how did you mount the cable chains for the x and y axis?
On my printers (cnc style frame) I have a printed end piece that mates with the carrier. That way I can fit to a specific hole pattern in sheet metal, to vslot, etc.
on the X I use a 8mm M5 and a T nut through the last part, then the open end is screwed into my X gantry plate in that notch. The Y is just screwed into my worktable, and then the other end is bolted on through one of the screws that hold the back 80mm extrusion.
Here’s a link to some photos I have of my build. I used an L bracket to attach the X and Y and the X lays on top of the stationary rear brace.
https://plus.google.com/105032363937415684606/posts/2RxeeBFMiie
