Question I purchased a reprap discount glcd. But it doesn't turn on.
Question
I purchased a reprap discount glcd. But it doesn’t turn on.
I connected all the new pins to the smoothieboard as you can see in the picture.
I have a 5v regulator 1 amp on the smoothieboard.
Here’s the configuration file for the panel.
https://www.dropbox.com/s/m07qc40bhb8s3e6/config1?dl=0
Did I miss something.
On the configuration file ignore the file name “config1” I made it that way so I don’t get confused with the real configuration file. It’s just a copy
PS. I have the red glcd from Amazon
And the red adaptor for the smoothieboard.
OK so I took another shot at it. And I got the screen to come on. But it’s just a blank blue screen. And now the number four green LED light is not on. Meaning that there’s a SD card problem. Is that because there’s an external SD card slot on the glcd? Please help
on mine I had to reverse the connections to the adapter board. Easy way is to nip off the keyed section and insert backwards. It is a common issue for the non-genuine boards and took me a while to find it myself.
@Domm434 ​ I’ll try that. Thanks
@Domm434 it works it’s much brighter. But there’s no display still? Like everyone else has it saying smoothie ready. How do I get it to do this.
Thanks
@Domm434 this is what it looks like.
