Question: Should I try blackening aluminum?
I’ve seen several 20W scanning lasers (laser markers with galvos) do the trick (though they guard their settings unless you buy from them), but one thing I’m worried about with the K40 is that in the K40, the laser is perpendicular to the object, so if the light gets reflected back into the tube, you can overload it… (not a problem for galvo scanners because what gets reflected scatters into the room [and you! wear protection!])
Anyone done this with a K40 and willing to share settings or should I stay away from this?
