Ran into a new issue on one of my bots.
Ran into a new issue on one of my bots. I can sustain heat when manually turned on in RepHost, but within 30 seconds after starting a print…the head starts to cool and then emergency shutdown. Any advice?
Loose connection that lets go when the head starts shaking?
Or perhaps the thermistor is shorting out?
Its probably a loose connection. This machine particularly is pretty tightly wired so maybe it just snagged somewhere. Nothing is disconnected though so I’ll have to run a multimeter to find the issue
My guess as well would be a loose connection, based on experiencing this exact same thing first hand.
Definitely a loose connection. If it’s a Bukobot, it’s most likely in the screw terminals on the X carriage.
@Nope_Nope I think you commented in the wrong post.
@Ben_Van_Den_Broeck so I did…
must be time for another coffee
Issue fixed, it was a loose connection. The fan wire popped out of the screw terminal.
