I’m using the Smoothieboard to run a 3D printer, and I’m running into an issue where I’m getting random hangs during print jobs. It can happen immediately, or it can happen six hours into a long print. The same file will sometimes run fine, and sometimes hang. The location of the hang is not consistent.
I can’t past links yet, so I’m going to drop my config file and some terminal logs here. Apologize for the length.
This is what the terminal log looks like when it hangs. Suddenly I start seeing responses that look like gibberish. Octoprint can’t parse it, and printing stops. This particular chunk of terminal code is from after doing a system restart on Octoprint. Nothing will cause the Smoothieboard to reconnect again until I do a full power cycle on the machine, taking everything down. Then it works again as normal.
Send: N0 M110 N0*125
Recv: $T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5$T050c:ffffffff;0d:187f0010;0e:4bc70000;0f:4ac70000;#b5
Baudrate test retry: 4
Baudrate test retry: 3
Baudrate test retry: 2
Baudrate test retry: 1
Baudrate test retry: 0
And here’s my config file!
# Smoothieboard configuration file # NOTE Lines must not exceed 132 characters, and '#' characters mean what follows is ignored ## Robot module configurations : general handling of movement G-codes and slicing into movesBasic motion configuration
default_feed_rate 4000 # Default speed (mm/minute) for G1/G2/G3 moves
default_seek_rate 4000 # Default speed (mm/minute) for G0 moves
mm_max_arc_error 0.01 # The maximum error for line segments that divide arcs 0 to disable
# note it is invalid for both the above be 0
# if both are used, will use largest segment length based on radiusArm solution configuration : Cartesian robot. Translates mm positions into stepper positions
Se
alpha_steps_per_mm 320 # Steps per mm for alpha ( X ) stepper
beta_steps_per_mm 320 # Steps per mm for beta ( Y ) stepper
gamma_steps_per_mm 3200 # Steps per mm for gamma ( Z ) stepper
arm_solution cartesian #Planner module configuration : Look-ahead and acceleration configuration
See
planner_queue_size 32 #
acceleration 1000 # Acceleration in mm/second/second.
z_acceleration 500 # Acceleration for Z only moves in mm/s^2, 0 uses acceleration which is the default. DO NOT SET ON A DELTA
junction_deviation 0.08 # See
z_junction_deviation 0 # For Z only moves, -1 uses junction_deviation, zero disables junction_deviation on z moves DO NOT SET ON A DELTA
#alpha_acceleration 500 #
#beta_acceleration 2000 #Cartesian axis speed limits
x_axis_max_speed 30000 # Maximum speed in mm/min
y_axis_max_speed 30000 # Maximum speed in mm/min
z_axis_max_speed 300 # Maximum speed in mm/minStepper module configuration
Pins are defined as ports, and pin numbers, appending “!” to the number will invert a pin
See
alpha_step_pin 2.0 # Pin for alpha stepper step signal
alpha_dir_pin 0.5! # Pin for alpha stepper direction, add ‘!’ to reverse direction
alpha_en_pin 0.4 # Pin for alpha enable pin
alpha_current 1.4 # X stepper motor current
alpha_max_rate 30000.0 # Maximum rate in mm/minbeta_step_pin 2.1 # Pin for beta stepper step signal
beta_dir_pin 0.11 # Pin for beta stepper direction, add ‘!’ to reverse direction
beta_en_pin 0.10 # Pin for beta enable
beta_current 0.7 # Y stepper motor current
beta_max_rate 30000.0 # Maxmimum rate in mm/mingamma_step_pin 2.2 # Pin for gamma stepper step signal
gamma_dir_pin 0.20! # Pin for gamma stepper direction, add ‘!’ to reverse direction
gamma_en_pin 0.19 # Pin for gamma enable
gamma_current 1.2 # Z stepper motor current
gamma_max_rate 300.0 # Maximum rate in mm/minExtruder module configuration
See
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 1390 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend.max_speed 50 # Maximum speed in mm/s
extruder.hotend.step_pin 2.3 # Pin for extruder step signal
extruder.hotend.dir_pin 0.22 # Pin for
Thanks so much for the help. It’s a great board and a great system, just seeing weird behavior.
