“Red, White, and Blue” Challenge!
While the LEDs are “Red, Green, and Blue”, there are times when it’s fun to run a “Red, White, and Blue” animation! With all the great folks here, I thought it might be fun to propose a color theme for the week: code up and show off some a “Red, White, and Blue” themed animation, and if you can, share the code so that other people can play with it and build on it!
Starting Hint: if you download the FastLED 2.1 branch from github, the “ColorPalette” example has a Red, White, and Blue color palette already coded into it, as well as a bunch of other palettes, which you can just disable…
Update: I also posted a new ‘starter sketch’ using a Red-White-and-Blue palette here: https://gist.github.com/kriegsman/ccffc81a74bc03636ce1 Run, remix, repost, and have fun!
