Repetier .95C connects but my bot will not move. Uninstalled and re installed in the same directory as .85. .85 will still work properly if .95C is not open. .NET4 is installed. I have all the drivers installed or .85 would not work. Not sure what the deal is. Goggling this didn’t bring up anything so it must be something i have or haven’t done. Any advise?
Check this post: http://help.printrbot.com/Answers/View/1242/No+activity+from+printrbot
Repetier changed a default setting between versions.
Update. Working. There is new settings that i am not used to. For example: Rest on connect, This needs to be in the disabled mode. This was the whole problem for me.
@Wayne_Friedt was that from that post or had you worked it out earlier? Either way, glad to hear it’s working!
I had fixed it just before you posted. Thanks for looking out for me tho.
Hope i can return it some time.
