Request for Dev. Help.
TLDR; * I need help making a widget that will connect to a Arduino Nano to poll and display events. I’ve been trying to do it, But I lack the coding chops to get it to work. At all. *
The project in question. I’ve made a RPM Tach / Speed controller for the DWP611. The RPM Sensing is done with a IR rx/tx thats pointed at the collet on the 611 with a thin strip of reflective tape. The speed control (more like speed setting) part is done by bypassing the Analog Pot on the 611 and replacing it with a Digipot thats connected to the Arduino Nano. That Arduino in-turn is connected to the Spindle PWM pin connected to an Due running TinyG2. And lastly a temp sensor taped on the 611s chassis with kapton tape. All of this works so far.
The Part I having great difficulty with is getting the output from the nano to CP.
I am passing :
Spindle : ON / OFF
RPM:
Max:
Min:
Temp:
The exact variable that the nano is passing is:
DWP611:ON RPM:8512 MAX:8591 MIN:8499 TEMP: 94.6F
I’d like to read all this into a widget similar to the DRO widget. With the only exception is the Spindle on would be a Red / Green dot.
As of now, This is only a “Set this RPM and monitor” It currently does not attempt to maintain that rpm if it dips (Yet)… Still working on that.
If anyone with the coding know-how wants to help. Please let me know.
