Retrieving firmware from smoothieboard??
Good afternoon. First time poster :slight_smile:
I inherited a azteeg smoothieboard in a 3d DLP printer that I bought. I can recover the configuration files off of the SD card that is in the board, but is there also a flashed firmware that I need to be making sure I back up?
If so, is there any way to get a bin file created from the board? I know with Ramps/Rambo boards ive used in the past you cant pull the config, only write to it when you have an available BIN.
thank you advance
You can not retrieve the firmware from the Smoothieboard, but you do not need to.
All configuration is in the “config” file. The firmware itself is generic and you can just get a new one from the website.
