Review of the Folger Tech 2020 i3 kit up on my blog!
http://overworlddesigns.blogspot.com/2016/01/review-folger-tech-2020-i3-kit.html
nice review, did it come with the inductive sensor? I hope FolgerTech sells a cheap printer where the bed only moves in the Z or not at all- those seem better for larger printer designs.
Thanks for this. I just got done building their Delta and they have a few errors with that too. I followed their YouTube tutorials and ended up making some minor mods. I hope they sort out their Firmware versions. They really should keep that closer up to date. I need to install what they have on the Delta before I fire it up. Like you I installed a lit switch for main power but I also printed some cable chain. I tucked a lot of wiring into the slots and covered that up with slot covers.
@Samer_Najia I just built their delta too. Their instructions to get the bed level never worked for me. How about you?
@Keith_Applegarth
You might want to reprint the bearing holders. Mine seemed less than great and I think they put the bed worse off level. That said, leveling the bed on this one is no different than most other printers. Plus I installed an inductive sensor for auto bed tramming, so I don’t bother with my bed any more anyway.
@Ted_Huntington
No, I bought the inductive sensor on Ebay.
@Keith_Applegarth still have to load the firmware. A bit dodgy with the servo but if it doesn’t level I might put springs under it and level it that way.
@Samer_Najia I have the inductive sensor and found a firmware with an autocalibration feature. Take a look here:https://github.com/RichCattell/Marlin
It is for the kossel delta and I do have issues with the autocalibration feature. BUT, it does work.
@Keith_Applegarth , I would need to re-do the effector install to put the inductive sensor in would I not?
@Samer_Najia part of it. You’d need to replace the bottom part of the effector.
@Keith_Applegarth you mean that part holding the fan and Jhead, right? That’s just 4 screws and i can repurpose the tap switch connection (I would need a diode too right?) and put the 9G servo on one my tanks instead presumably?
@Keith_Applegarth forgot to ask…what part are you using as a replacement and what issues did you have with autocalibration? In other words, do you have a firmware package you have tuned for me to try?
The STL files are on the Dropbox for the v2. Each printer will be a but different depending on your build. Follow the instructions on the github I posted before. If you have an issue, then let me know.
Ok will do. Do you see any benefit with getting it running as is now and converting or just convert immediately?
Not sure… Now or later… fix it once or twice… If it were me, I would probably just do it. Otherwise, you are setting it up, calibrating, then tearing it apart to calibrate it again…
