ROKO SN04-N sensor.
The above came with my Anet A8 Prusa i3 kit (actually I paid an extra $15 for it) to enable auto-leveling. It’s a little blue sensor with a red LED.
You’re supposed to be able to plug it into the Z-axis sensor spot on the board. When I do so, and test it, the red LED doesn’t light up.
I suspect it’s because the board provides 5 volts through the Z-axis sensor socket, but the ROKO states 10-30 volts to operate. others have said that it CAN work with 5 volts, but not reliably.
I could easily route 12 volts to the sensor, but then I’m worried that the board might burn out if I don’t use something like a logic level converter. But that’s going to cost over $10 – so I’d rather buy a new sensor that’s compatible.
UNLESS… any of you have had success getting this sensor to work with your setup.
