Room temperature hack! I run boards off printers often enough I made a tool.
Room temperature hack! I run boards off printers often enough I made a tool. 100K resistor on a 0.1" plug. This stops Marlin winging about the hot end so much.
Yep, and the lower you go, you can simulate the hot end being at temperature if you want as well.
