Saw this over at make,
Saw this over at make, and its a great idea! Kudos to andrew terranova for his quick thinking the hulk was saved! :slight_smile:
Originally shared by David Clunie
This is a great idea!!! @David_Tam @Melissa_Blanchard
http://www.dbclunie.com/2015/06/hot-glue-can-save-your-failing-print.html
But they’re still failed prints.
When I’m designing mechanical parts, it usually takes at least a half dozen prints to dial in all the dimensions. Saving one or two failures during that process would save a lot of time, and I’d still be able to test fit the completed “failures” and see if I got some of the numbers right.
