Second Extruder Control ???
Trying to set up a dual extruder but am only 3/4 there. First extruder works (T) temperature control is good, and extrusion is good, have successful prints with first extruder. The second extruder (T1) has temperature control, but will only extrude from the first extruder (T) no matter which tool (0 or 1 in Pronterface or Web Server) is selected. Verified that the second extruder works by swapping the delta/epsilon pin assignments and inverting the direction pin to compensate for that extruder being reversed (enable, direction, step), epsilon hardware and mechanicals work and the epilon extruder works as the first extruder. Using the Edge firmware dated 25-July-2014, Config file follows. Pronterface temperature graph shows good values for Ex0, Ex1, Bed.
Am I missing something?
GD.
#### PRusa i3 Stretch ver 1.00 26-Jul-2014
  1. Robot module configurations : general handling of movement G-codes and slicing into moves
default_feed_rate 4000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 4000 # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment 0.5 # Arcs are cut into segments ( lines ), this is the length for these segments. Smaller values mean more resolution, higher values mean faster computation
mm_per_line_segment 5 # Lines can be cut into segments ( not usefull with cartesian coordinates robots ).
  1. Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
alpha_steps_per_mm 80 # Steps per mm for alpha stepper
beta_steps_per_mm 80 # Steps per mm for beta stepper
gamma_steps_per_mm 4000 # Steps per mm for gamma stepper
  1. Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # Size of the planning queue, must be a power of 2. 128 seems to be the maximum.
acceleration 3000 # Acceleration in mm/second/second.
acceleration_ticks_per_second 1000 # Number of times per second the speed is updated
junction_deviation 0.05 # Similar to the old “max_jerk”, in millimeters, see :
# and . Lower values mean being more careful, higher values means being faster and have more jerk
  1. Stepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
minimum_steps_per_minute 1200 # Never step slower than this
base_stepping_frequency 100000 # Base frequency for stepping, higher gives smoother movement
  1. Stepper module pins ( ports, and pin numbers, appending “!” to the number will invert a pin )
alpha_step_pin 2.0 # Pin for alpha stepper step signal
alpha_dir_pin 0.5 # Pin for alpha stepper direction
alpha_en_pin 0.4 # Pin for alpha enable pin
alpha_current 0.75 # X stepper motor current
x_axis_max_speed 4000 # mm/min
beta_step_pin 2.1 # Pin for beta stepper step signal
beta_dir_pin 0.11! # Pin for beta stepper direction
beta_en_pin 0.10 # Pin for beta enable
beta_current 0.75 # Y stepper motor current
y_axis_max_speed 4000 # mm/min
gamma_step_pin 2.2 # Pin for gamma stepper step signal
gamma_dir_pin 0.20! # Pin for gamma stepper direction
gamma_en_pin 0.19 # Pin for gamma enable
gamma_current 1.25 # Z stepper motor current
z_axis_max_speed 200 # mm/min
  1. Serial communications configuration ( baud rate default to 9600 if undefined )
uart0.baud_rate 115200 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface and a terminal connected)
#leds_disable true # disable using leds after config loaded
#play_led_disable true # disable the play led
  1. Extruder module configuration
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 1400 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 4000 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 800 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
extruder.hotend.max_speed 40 # mm/s
extruder.hotend.step_pin 2.3 # Pin for extruder step signal
extruder.hotend.dir_pin 0.22 # Pin for extruder dir signal
extruder.hotend.en_pin 0.21 # Pin for extruder enable signal
delta_current 0.67 # Extruder stepper motor current
  1. firmware retract settings when using G10/G11, these are the defaults if not defined, must be defined for each extruder if not using the defaults
extruder.hotend.retract_length 1.25 # retract length in mm
extruder.hotend.retract_feedrate 50 # retract feedrate in mm/sec
extruder.hotend.retract_recover_length .25 # additional length for recover
extruder.hotend.retract_recover_feedrate 8 # recover feedrate in mm/sec (should be less than retract feedrate)
extruder.hotend.retract_zlift_length 0 # zlift on retract in mm, 0 disables
extruder.hotend.retract_zlift_feedrate 6000 # zlift feedrate in mm/min (Note mm/min NOT mm/sec)
  1. extruder offset
extruder.hotend.x_offset 0 # x offset from origin in mm
extruder.hotend.y_offset 0 # y offset from origin in mm
extruder.hotend.z_offset 0 # z offset from origin in mm
settings for second extruder
extruder.hotend2.module_enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend2.steps_per_mm 1400 # Steps per mm for extruder stepper
extruder.hotend2.default_feed_rate 4000 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend2.acceleration 800 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
extruder.hotend2.max_speed 40 # mm/s
extruder.hotend2.step_pin 2.8 # Pin for extruder step signal
extruder.hotend2.dir_pin 2.13! # Pin for extruder dir signal
extruder.hotend2.en_pin 4.29 # Pin for extruder enable signal
epsilon_current 0.67 # 5th axis
extruder.hotend2.retract_length 1.25 # retract length in mm
extruder.hotend2.retract_feedrate 50 # retract feedrate in mm/sec
extruder.hotend2.retract_recover_length .25 # additional length for recover
extruder.hotend2.retract_recover_feedrate 8 # recover feedrate in mm/sec (should be less than retract feedrate)
extruder.hotend2.retract_zlift_length 0 # zlift on retract in mm, 0 disables
extruder.hotend2.retract_zlift_feedrate 6000 # zlift feedrate in mm/min (Note mm/min NOT mm/sec)
  1. extruder offset
extruder.hotend2.x_offset 25 # x offset from origin in mm
extruder.hotend2.y_offset 0 # y offset from origin in mm
extruder.hotend2.z_offset 0 # z offset from origin in mm
  1. Laser module configuration
laser_module_enable false # Whether to activate the laser module at all. All configuration is ignored if false.
#laser_module_pin 2.7 # this pin will be PWMed to control the laser
#laser_module_max_power 0.8 # this is the maximum duty cycle that will be applied to the laser
#laser_module_tickle_power 0.0 # this duty cycle will be used for travel moves to keep the laser active without actually burning
  1. Hotend temperature control configuration
temperature_control.hotend.enable true # Whether to activate this ( “hotend” ) module at all.
# All configuration is ignored if false.
temperature_control.hotend.link_to_tool true # This tells smoothie to enable and disable control of this hotend at the same time as the extruder of the same name
temperature_control.hotend.thermistor_pin 0.23 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.7 # Pin that controls the heater
temperature_control.hotend.thermistor Semitec # see src/modules/tools/temperaturecontrol/TemperatureControl.cpp:64 for a list of valid thermistor names
temperature_control.hotend.designator T #
temperature_control.hotend.p_factor 45 # permanenetly set the PID values after an auto pid
temperature_control.hotend.i_factor 8.2 #
temperature_control.hotend.d_factor 61 #
temperature_control.hotend.max_pwm 225 # override max pwm, 64 is a good value if driving a 12v resistor with 24v.
  1. Hotend2 temperature control configuration
temperature_control.hotend2.enable true # Whether to activate this ( “hotend” ) module at all.
temperature_control.hotend2.link_to_tool true # This tells smoothie to enable and disable control of this hotend at the same time as the extruder of the same name
temperature_control.hotend2.thermistor_pin 0.25 # Pin for the thermistor to read
temperature_control.hotend2.heater_pin 1.23 # Pin that controls the heater
temperature_control.hotend2.thermistor Semitec # see src/modules/tools/temperaturecontrol/TemperatureControl.cpp:64
# for a list of valid thermistor names
temperature_control.hotend2.set_m_code 104 #
temperature_control.hotend2.set_and_wait_m_code 109 #
temperature_control.hotend2.designator T1 #
temperature_control.hotend2.p_factor 45 # permanently set the PID values after an auto pid
temperature_control.hotend2.i_factor 8.2 #
temperature_control.hotend2.d_factor 61 #
temperature_control.hotend2.max_pwm 225 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
temperature_control.bed.enable true #
temperature_control.bed.thermistor_pin 0.24 #
temperature_control.bed.heater_pin 1.22 # Small MosFet for SSR control
temperature_control.bed.output_type digital # On/Off only
temperature_control.bed.pwm_frequency 1 # 20Hz Max switching Freq
temperature_control.bed.thermistor EPCOS100K # see src/modules/tools/temperaturecontrol/TemperatureControl.cpp:64 for a list of valid thermistor names
temperature_control.bed.set_m_code 140 #
temperature_control.bed.set_and_wait_m_code 190 #
temperature_control.bed.designator B #
#temperature_control.bed.bang_bang false # set to true to use bang bang control rather than PID
#temperature_control.bed.hysteresis 2.0 # set to the temperature in degrees C to use as hysteresis
# when using bang bang
  1. Switch module for fan control
switch.fan.enable false #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 2.6 #
switch.fan.output_type pwm # pwm output settable with S parameter in the input_on_comand
#switch.fan.max_pwm 255 # set max pwm for the pin default is 255
#switch.misc.enable true #
#switch.misc.input_on_command M42 #
#switch.misc.input_off_command M43 #
#switch.misc.output_pin 2.4 #
#switch.misc.output_type digital # just an on or off pin
  1. automatically toggle a switch at a specified temperature
  2. useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable true #
#temperatureswitch.hotend.type misc # select which MOSFET to use, fan or misc (small MOSFETs)
#temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervals
  1. Switch module for spindle control
#switch.spindle.enable false #
  1. Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
#corexy_homing false # set to true if homing on a hbit or corexy
alpha_min_endstop 1.24^ # add a ! to invert if endstop is NO connected to ground
alpha_max_endstop 1.25^ #
alpha_homing_direction home_to_min # or set to home_to_max and set alpha_max
alpha_min 0 # this gets loaded after homing when home_to_min is set
alpha_max 200 # this gets loaded after homing when home_to_max is set
beta_min_endstop 1.26^ #
beta_max_endstop 1.27^ #
beta_homing_direction home_to_min #
beta_min 0 #
beta_max 300 #
gamma_min_endstop 1.28^ #
gamma_max_endstop 1.29^ #
gamma_homing_direction home_to_min #
gamma_min 0 #
gamma_max 200 #
alpha_fast_homing_rate_mm_s 50 # feedrates in mm/second
beta_fast_homing_rate_mm_s 50 # "
gamma_fast_homing_rate_mm_s 3 # "
alpha_slow_homing_rate_mm_s 25 # "
beta_slow_homing_rate_mm_s 25 # "
gamma_slow_homing_rate_mm_s 1 # "
alpha_homing_retract_mm 5 # distance in mm
beta_homing_retract_mm 5 # "
gamma_homing_retract_mm 1 # "
#endstop_debounce_count 100 # uncomment if you get noise on your endstops
  1. Pause button
pause_button_enable true #
  1. Panel
panel.enable false # set to true to enable the panel code
panel.lcd smoothiepanel # set type of panel also viki_lcd, i2c_lcd is a generic i2c panel, panelolu2
panel.encoder_a_pin 3.25!^ # encoder pin
panel.encoder_b_pin 3.26!^ # encoder pin
  1. Example for reprap discount GLCD
  2. on glcd EXP1 is to left and EXP2 is to right, pin 1 is bottom left, pin 2 is top left etc.
  3. +5v is EXP1 pin 10, Gnd is EXP1 pin 9
#panel.lcd reprap_discount_glcd #
#panel.spi_channel 0 # spi channel to use ; GLCD EXP1 Pins 3,5 (MOSI, SCLK)
#panel.spi_cs_pin 0.16 # spi chip select ; GLCD EXP1 Pin 4
#panel.encoder_a_pin 3.25!^ # encoder pin ; GLCD EXP2 Pin 3
#panel.encoder_b_pin 3.26!^ # encoder pin ; GLCD EXP2 Pin 5
#panel.click_button_pin 1.30!^ # click button ; GLCD EXP1 Pin 2
#panel.buzz_pin 1.31 # pin for buzzer ; GLCD EXP1 Pin 1
#panel.button_pause_pin 2.11^ # kill/pause ; GLCD EXP2 Pin 8
  1. pins used with other panels
#panel.up_button_pin 0.1! # up button if used
#panel.down_button_pin 0.0! # down button if used
#panel.click_button_pin 0.18! # click button if used
panel.menu_offset 0 # some panels will need 1 here
panel.gamma_jog_feedrate 200 # z jogging feedrate in mm/min
panel.hotend_temperature 185 # temp to set hotend when preheat is selected
panel.bed_temperature 60 # temp to set bed when preheat is selected
  1. Example of a custom menu entry, which will show up in the Custom entry.
  2. NOTE _ gets converted to space in the menu and commands, | is used to separate multiple commands
custom_menu.power_on.name Power_on #
custom_menu.power_on.command M80 #
custom_menu.power_off.enable true #
custom_menu.power_off.name Power_off #
custom_menu.power_off.command M81 #
  1. Only needed on a smoothieboard
currentcontrol_module_enable true #
return_error_on_unhandled_gcode false #
  1. network settings
network.enable true # enable the ethernet network services
network.webserver.enable true # enable the webserver
network.telnet.enable true # enable the telnet server
network.ip_address auto # use dhcp to get ip address
  1. uncomment the 3 below to manually setup ip address
network.ip_address 192.168.0.156 # the IP address
network.ip_mask 255.255.255.0 # the ip mask
network.ip_gateway 192.168.0.1 # the gateway address
#network.mac_override xx.xx.xx.xx.xx.xx # override the mac address, only do this if you have a conflict
It looks like you are not missing anything.
I see one thing that is strange : one module as .enable, the other has .module_enable.
Can you try changing both to .module_enable ?
Cheers.
Hi everyone!
My name is Luis and this is my first message here. I am trying to config dual extrusion and I have same issue. Changing the tool from pronterface moves always the same motor. I swapped the motor pins and both work but with same issue. I am not using temperature control modules, I mainly print with foods that do not require it (easier :slight_smile: ). I tried to change from .enable to module_enable but that makes both extruders not to move.
# NOTE Lines must not exceed 132 characters
# Robot module configurations : general handling of movement G-codes and slicing into moves
                                                              # these segments.  Smaller values mean more resolution,
                                                              # higher values mean faster computation
#mm_per_line_segment                         0.5              # Lines can be cut into segments ( not useful with cartesian
                                                              # coordinates robots ).
delta_segments_per_second                    100              # for deltas only same as in Marlin/Delta, set to 0 to disable
                                                              # and use mm_per_line_segment
arm_solution linear_delta # selects the delta arm solution
alpha_steps_per_mm 100 # Steps per mm for alpha stepper
beta_steps_per_mm 100 # Steps per mm for beta stepper
gamma_steps_per_mm 100 # Steps per mm for gamma stepper
arm_length 250.0 # this is the length of an arm from hinge to hinge
arm_radius 124.0 # this is the horizontal distance from hinge to hinge
# when the effector is centered
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOU ARE DOING
# Lower values mean being more careful, higher values means being
# faster and have more jerk
#minimum_planner_speed 0.0 # sets the minimum planner speed in mm/sec
Cartesian axis speed limits
x_axis_max_speed 30000 # mm/min
y_axis_max_speed 30000 # mm/min
z_axis_max_speed 30000 # mm/min
alpha_current 1.5 # X stepper motor current
alpha_max_rate 30000.0 # mm/min
beta_dir_pin 0.11 # Pin for beta stepper direction
beta_current 1.5 # Y stepper motor current
beta_max_rate 30000.0 # mm/min
gamma_dir_pin 0.20 # Pin for gamma stepper direction
gamma_current 1.5 # Z stepper motor current
gamma_max_rate 30000.0 # mm/min
# and a terminal connected)
#msd_disable false # disable the MSD (USB SDCARD) when set to true
extruder.hotend.steps_per_mm 140 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
extruder.hotend.max_speed 50 # mm/s
extruder offset
extruder.hotend.y_offset 0.5 # y offset from origin in mm
extruder.hotend.retract_length 3 # retract length in mm
extruder.hotend.retract_feedrate 45 # retract feedrate in mm/sec
extruder.hotend.retract_recover_length 0 # additional length for recover
delta_current 1.5 # First extruder stepper motor current
Second extruder module configuration example
extruder.hotend2.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend2.steps_per_mm 140 # Steps per mm for extruder stepper
extruder.hotend2.default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend2.acceleration 500 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
extruder.hotend2.max_speed 50 # mm/s
extruder.hotend2.dir_pin 2.13 # Pin for extruder dir signal
extruder.hotend2.x_offset 0 # x offset from origin in mm
#epsilon_current 1.5 # Second extruder stepper motor current
# ignored if false.
#laser_module_pin 2.5 # this pin will be PWMed to control the laser. Only P2.0 - P2.5, P1.18, P1.20, P1.21, P1.23, P1.24, P1.26, P3.25, P3.26
# can be used since laser requires hardware PWM
#laser_module_maximum_power 1.0 # this is the maximum duty cycle that will be applied to the laser
#laser_module_minimum_power 0.0 # This is a value just below the minimum duty cycle that keeps the laser
# active without actually burning.
#laser_module_default_power 0.8 # This is the default laser power that will be used for cuts if a power has not been specified. The value is a scale between
# the maximum and minimum power levels specified above
#laser_module_pwm_period 20 # this sets the pwm frequency as the period in microseconds
temperature_control.hotend.enable false # Whether to activate this ( “hotend” ) module at all.
temperature_control.hotend.thermistor EPCOS100K #
#temperature_control.hotend.beta 4066 # or set the beta value
temperature_control.hotend.designator H1 #
#temperature_control.hotend.max_temp 300 # Set maximum temperature - Will prevent heating above 300 by default
#temperature_control.hotend.min_temp 0 # Set minimum temperature - Will prevent heating below 0 by default
#temperature_control.hotend.p_factor 13.7 # permanently set the PID values after an auto pid
#temperature_control.hotend.i_factor 0.097 #
#temperature_control.hotend.d_factor 24 #
#temperature_control.hotend.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
#temperature_control.hotend2.enable false # Whether to activate this ( “hotend” ) module at all.
#temperature_control.hotend2.thermistor_pin 0.25 # Pin for the thermistor to read
#temperature_control.hotend2.heater_pin 1.23 # Pin that controls the heater
#temperature_control.hotend2.thermistor EPCOS100K #
##temperature_control.hotend2.beta 4066 # or set the beta value
#temperature_control.hotend2.set_m_code 884 #
#temperature_control.hotend2.set_and_wait_m_code 889 #
#temperature_control.hotend2.designator H2 #
#temperature_control.hotend2.p_factor 13.7 # permanently set the PID values after an auto pid
#temperature_control.hotend2.i_factor 0.097 #
#temperature_control.hotend2.d_factor 24 #
#temperature_control.hotend2.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
temperature_control.bed.heater_pin 2.5 #
temperature_control.bed.thermistor Honeywell100K #
#temperature_control.bed.beta 4066 # or set the beta value
switch.fan.enable true #
automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
#temperatureswitch.hotend.designator H0 # first character of the temperature control designator to use as the temperature sensor to monitor
#temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
Endstops
delta_homing true # forces all three axis to home a the same time regardless of
# what is specified in G28
alpha_min_endstop nc #
alpha_max_endstop 1.25^! # add ! to invert pullup if switch is NO to ground
alpha_homing_direction home_to_max # Home up
alpha_max 0 #
beta_min_endstop nc #
beta_max_endstop 1.27^! #
beta_homing_direction home_to_max #
beta_max 0 #
gamma_min_endstop nc #
gamma_max_endstop 1.29^! #
gamma_homing_direction home_to_max #
gamma_max 300 #
alpha_fast_homing_rate_mm_s 200 # homing feedrates in mm/second
beta_fast_homing_rate_mm_s 200 #
gamma_fast_homing_rate_mm_s 200 #
alpha_slow_homing_rate_mm_s 20 #
beta_slow_homing_rate_mm_s 20 #
gamma_slow_homing_rate_mm_s 20
alpha_homing_retract_mm 5 # retract/bounce distance after homing in mm
gamma_homing_retract_mm 5 #
alpha_trim 0 # software trim for alpha stepper endstop (in mm)
beta_trim 0 # software trim for beta stepper endstop (in mm)
gamma_trim 0 # software trim for gamma stepper endstop (in mm)
optional Z probe
zprobe.enable false # set to true to enable a zprobe
zprobe.probe_pin 1.28!^ # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 5 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 100 # move feedrate mm/sec
zprobe.probe_height 5 # how much above bed to start probe
#gamma_min_endstop nc # normally 1.28. Change to nc to prevent conflict,
associated with zprobe the leveling strategy to use
#leveling-strategy.delta-calibration.enable true # basic delta calibration
#leveling-strategy.delta-calibration.radius 100 # the probe radius
Pause button
Panel
#panel.button_pause_pin 2.11^ # kill/pause ; GLCD EXP2 Pin 8 either
#panel.back_button_pin 2.11!^ # back button ; GLCD EXP2 Pin 8 or
network settings
network.enable false # enable the ethernet network services
#network.ip_address 192..168..3..222 # the IP address
#network.ip_mask 255..255..255..0 # the ip mask
#network.ip_gateway 192..168..3..1 # the gateway address
I also have a config_override, not sure if that affects but since.
; DO NOT EDIT THIS FILE
;Steps per unit:
M92 X80.00000 Y80.00000 Z80.00000
;Acceleration mm/sec^2:
M204 S3000.00000 Z0.00000
;X- Junction Deviation, Z- Z junction deviation, S - Minimum Planner speed mm/sec:
M205 X0.05000 Z-1.00000 S0.00000
;Max feedrates in mm/sec, XYZ cartesian, ABC actuator:
M203 X500.00000 Y500.00000 Z500.00000 A500.00000 B500.00000 C500.00000
;Optional arm solution specific settings:
M665 L233.0000 R132.5000
;Motor currents:
M907 X1.50000 Y1.50000 Z1.50000 E0.40000
;Home offset (mm):
M206 X0.00 Y0.00 Z14.70
;Trim (mm):
M666 X-4.900 Y-6.400 Z-6.700
;Max Z
M665 Z120.000
;E Steps per mm:
M92 E1600.0000 P57988
;E Filament diameter:
M200 D0.0000 P57988
;E retract length, feedrate:
M207 S3.0000 F2700.0000 Z0.0000 Q6000.0000 P57988
;E retract recover length, feedrate:
M208 S0.0000 F480.0000 P57988
;E acceleration mm/sec^2:
M204 E500.0000 P57988
;PID settings:
M301 S0 P10.0000 I0.3000 D200.0000 X255.0000 Y255
;PID settings:
M301 S1 P10.0000 I0.3000 D200.0000 X255.0000 Y25
Thanks a lot in advance, I will keep trying to solve, meanwhile anyhelp is more than welcome!
Yes, shame on me. I just lost 2 days because I did not pay any attention at all. The second extruder and the temperature module for it were commented!! I uncommented and it works!
Sorry for it. I hope nobody does this rookie mistake.
moving forward!
That was it, both extruders are feeding as commanded.
Thanks
GD
