Sending g-code via USB RS232?
Hi,
We need to build a measurement setup which involves using stepping motors to move thing around. My colleague recommended me to use the SmoothieBoard to control the stepping motors. I have no previous experience with anything like this before. Is it possible to send g-code directly via a serial port terminal program? I need to do some measurements between the motor movement. Or I have to create many files, each corresponds to a specific g-code, and use play file command?
Thanks,
Joseph
Hello.
Yes, it is possible to send commands directly via a serial port terminal.
You do not need to create a file for each G-code. G-codes that are received are executed, the same way play commands that are received are executed.
Take a look here
and here
Cheers :slight_smile:
Hi Arthurwolf,
Thank you very much for your reply. I think we will go head then :slight_smile:
Joseph
I got the board and connected to the USB. I tried to talk to the board using a RS232 terminal (Termite). I can’t see the com port showed up. I also saw that Windows can’t find the driver. Do it require any software driver? What is the correct setting (baud rate, etc) for talking using serial?
Thanks,
Joseph
Hello.
The drivers are found here : http://smoothieware.org/windows-drivers and the baud rate is ignored so it is not important.
Cheers !
I’m having the problem that I cannot install any virtual driver as showed at that page.
This is what I have in my device manager:
Ports (COM & LPT)
Smoothieboard DFU Interface (COM12)
Smoothieboard USB Serial (COM11)
I have followed the instructions and I still can’t manage to do anything. Everything I try to execute the instructions given, it gives me a message saying : “Windows has determined the driver software for your device is up to date”
I need help
