After making several edits to the config file using Pronterface to set up GLCD Panel lost serial connection. Now get the following error.
[Error] Could not connect to com9 at baudrate 115200.
Serial Error: Could not open port 9: [Error2] the system could not find the file specified.
Any thoughts would be appreciated.
bouni_SW
(bouni_SW)
2
Hi,
Assuming you’re on Windows, go to the device Manager and check the serial devices. Maybe Windows gave it another Com port number!
That was my first thought, uninstalled and reinstalled the drivers, still port 9. Made no difference.
Replaced the config file and all is well. Not sure what pronterface did to the original file, will have to do a comparison to see.
