m getting a little confused with homing offsets (if thats the right terminology):
Basically I need to set the offset for my Prusa/Single Extraude from where it homes the X and Y to the endstops to where the actual corner of the print bed is.
The corner is approximate -30mm X and -11mm Y
Two questions:
- Which setting should I be using in the config files, so far it seems
extruder.module_name.x_offset -30
seems to be correct?
- is M206 the same as “extruder.module_name.x_offset” ?
Cheers
