setBrightness versus HSV If I use FastLED.setBrightness(63);
to set overall – or universal – brightness to about 1/4, and then later, in void loop I use…
leds[i] = CHSV( 224, 187, 255);
will that specific color override the setBrightness and display at full brightness?
No - the brightness that is set using setBrightness is applied to all the leds before they’re written out to the strip - think of it as a global volume knob - but for light, instead of sound.
Thank you!
Can I still use HSV to pick my colors?
(With the understanding that the V is basically negated)
I prefer HSV for color selection, and don’t minding setting all the individual V’s if I have to, but being able to use setBrightness is a nice “safety” when I’m experimenting with different effects – to avoid an unplanned for, amp-sucking display of all white full-bright.
V isn’t negated – for example, if you do setBrightness(128) and then do leds[0] = CHSV(255,255,255) and leds[1] = CHSV(255,255,128) – leds[0] is going to be at brightness 128 and leds[1] is going to be 64 – so the V value is still important - and all your relative V values will still be the same, relative to each other, scale wise. It’s just that setBrightness(128) will halve the brightness value of all the led data before writing it out.
Awesome!
That’s even handier than I had hoped!
Thanks for the detailed explanation and example.
