Hi There,
I have some trouble with my smoothie board configuration.
I have built a Laser cutter, using two stepper on a single axis (Y). I bought a smoothieboard 5ax to finally drive a 3 axis machine (XYZ) last driver maybe used in the future to drive a 4th rotary axis. I understood how to slave an axis in the general topics but only one endstop was used to do homing of both Y axis, but in my case, I need to do 2 differents homings (one for each Y axis) to adjust the perpendicularity of my XY plan.
I did this on my last CNC milling machine with MACH3 without any problems.
The question is : Is it possible on smoothieboard, to slave an axis, and then doing the homing at same time Y and Y’ as slave with their own endstops ?
Thanks for your support
