Smoothie - Prometheus extrusion problem .
I added a Prometheus dual extrusion system to a homebuilt Cartesian printer.
The extruders ( either one ) work perfectly when using a single filament process. When using a Dual filament process from Simplify 3D ( 4.0 ) the extruder motor does not rotate and there is no filament feed. It seems like the motor is stalled and makes strange noises. Almost like it is missing steps.
Anyone with any tips on where to look ?
S3D is possibly trying to move it too fast ? Maybe try reducing both acceleration and max speed for both extrders ?
Problem solved. The Prometheus( DisTech Automation ) provided starting script had a missing M83 code after a G90 E0 line.
Adding that line to the Gcode file manually resulted in printing immediately and I now added this line to the Simplify 3D process settings.
Script quoted below - The addition is on the last Gcode line.
; START SCRIPT START
M104 S[extruder0_temperature] T0
M140 S[bed0_temperature]
M190 S[bed0_temperature]
M109 S[extruder0_temperature] T0
G28 ; Home extruder
G90 ; Absolute positioning
G92 E0 ; Reset extruder position
M83
; START SCRIPT END
