Smoothieboard and NEMA motors
I found AvidCNC and I do like their machine kits. I am interested in the 5’ x 10’ cutting area one:
https://www.avidcnc.com/pro60120-5-x-10-cnc-router-kit-p-374.html?osCsid=jvblr64e8jlm3du9epn77ed0e1
However, their CNC machines uses NEMA 23 (3/8" shaft compatible) or NEMA 34 stepper motors (1/2" shaft compatible). Are those motors too powerful for a smoothieboard? What would I need to make this work?
Additionally, what can I use as limit switches?
I’m asking these questions because it would be nice to save money in the controller and software components.
To run the size motors you need for a large CNC router you need to break out the step, direction and enable signals to larger external drivers then what exist on board the smoothie. For the external drivers they aren’t cost prohibitively expensive. For example when I built my larger CNC I used nema 24 closed loop steppers. The stepper and driver together was under $100 a piece.
Oh awesome, sounds like a plan. What drivers did you use? And were the limit switches connected to these drivers as well or just the stepper motors?
Limit switches wire to the board. I use these on my new CNC (not smoothie based): https://www.amazon.com/dp/B07V4PR84Y/ref=cm_sw_r_cp_apa_glt_fabc_S28DF94D38N63TTNK5SK?_encoding=UTF8&psc=1
Here is the driver/motor combo I use on my new machine: https://www.omc-stepperonline.com/ye-series-1-axis-closed-loop-stepper-cnc-kit-3-0-nm-424-92oz-in-nema-24-motor-and-driver.html?search=1-CL57Y-24HE34
