Jayhoff_SW
(Jayhoff_SW)
November 1, 2015, 7:05pm
-brand new smoothieboard 4x
-Mk 2 heated bed with cork plate underneath
-plug in thermister and power to board
-pronterface does not pick up the thermistor (ie: reads 0 for temp)
so that’s my problem…any help would be appreciated, printing a school project and cold beds suck
Hey.
Can we see your configuration file on pastebin.com , a short description of what you plugged where, and the exact output of M105 ?
Cheers
Jayhoff_SW
(Jayhoff_SW)
November 2, 2015, 9:04pm
3
here’s a pastebin-
pastebin
.com
/qepKGDRj
what do you mean by the exact output of M105?
temperature_control.bed.heater_pin 2.5w #
Why do you have a w there ?
Also, can you give me a description of what you plugged where, as I asked in the previous message ?
Jayhoff_SW
(Jayhoff_SW)
November 3, 2015, 8:35pm
5
I plugged in the heat bed thermistor to T1 and the Heated bed power to P2_5
Can you try using T2 instead of T0 ( change config accordingly ) ?
Jayhoff_SW
(Jayhoff_SW)
November 4, 2015, 8:29am
7
Just realized I had temperature control bed set to " false". I set it to true and now everything works perfectly
Jayhoff_SW
(Jayhoff_SW)
November 3, 2015, 8:54pm
8
not sure why I have the W there, I have deleted it and it still doesn’t work…
