Hi all,
My printer (custom hw with smoothie board) looses moves. When I print non-banal objects at some time (never at the same point) my printer “looses a move”, and from that moment on shifts every path by 0,5……5mm on X or Y axis.
I am not talking about loosing steps, I suppose this would lead to imperfections in my prints, my diagnosis is that either Robot or Planner miss to interpret some gcodes.
When I send my extruder to (0,0,0) it actually returns to (ofsX, ofsY, 0), so I am quite sure it looses entire moves.
I tried many things to understand where problem could arise. On hardware side, I added a separate power supply for heated bed, just in case. I set the pulse length to 2uS. i tried to put a fan directly on motor drivers……no relief.
It seems like the problem is more frequent which rounded objects, so I supposed that firmware would eventually run out of blocks…I set planner_queue_size to 64 and now things seem to go better (1 object successfully printed so far).
But this could just be a fluke.
Should I add some printf’s in Planner/Robot.cpp etc in order to discover allocation/queue errors ?
Thank you, regards
Update: even with planner_queue_size set to 64 problem doesn’t disappear, sometimes gets even worse. I printed a threading twice. Firs result:
(please substitute @ with / and @@ with //, for some reason I cannot post links, low Karma
nice….second trial:
the shifting on x-axis is clear.
Both prints from the same file……pleas help, i am running out of ideas……
Do you have G3 G-codes in your G-code file ?
Hi, actually not, the only occurrence is a comment:
; arcReplaceG2G3,0
My files are generated by Simplify3D. If you want I can send you a file (2MB) that show this inconvenience almost at every print….
Here another trial:
http:@@postimg.org@image@7eke66fdl@
We have had several recent reports of problems with S3D.
Can you try :
- Generating the G-code with S3D, but sending it with Pronterface
- Generating the G-code with Slic3r and sending it with Pronterface
Thanks.
I am generating the G-code with S3D, copying to SD via filesystem and then launch printing from Pronterface (gcodes are red directly from SD). In the past I had bad experiences sending files directly from Pronterface (delays, bad arcs etc.)
I will try to slice my file with slic3r……but……why files sliced with S3D should perform differently at every print ? I suppose they should fail always at same point…….
Shall I reset planner_queue_size to 32 (or try with different values ?)
Yes, please try setting the size back to 32, and generating the G-code with Slic3r, and tell us if it makes a difference.
Hi, I have some interesting news
I re-sliced my object with slic3r (took a while to find out right parameters) and launched a print on my smoothie board-powered printer; so far, no more shift error (albeit slicing is much less efficient and printing is less “smooth”)
http:@@postimg.org@image@yzq6axmwn@
Yesterday evening, I sent S3D file to a friend’s printer (Ultimaker 2) and work came out quite perfect (gray item on the right)
http:@@postimg.org@image@jo0c3wqel@
So….sound like there is some misunderstanding between S3D and smoothieware…
If you give me an email address I can send you both files for further investigation.
Tks
Hi, I jus started printing a new object sliced with slic3r, and had same problem
http:@@postimg.org@image@uyf0hs1vz@
I just emailed you this file too (zipped)
Thanks
A few things to investigate in case of skipped steps :
- Reduce acceleration
- Reduce junction deviation ( divide by 10 each try )
- Make sure it’s not a mechanical problem ( most of the time it is )
- Make sure the current is set to the exact value specified for the steppers
- Make sure there is no over-heating of the drivers ( rare )
Cheers.
Hi, I followed your suggestions, one by one
After many trials, reducing acceleration from 3000 to 1500 mm/second/second seem to solve problem.Obviously my printer is quite slower now.
I will make more trial prints, to be sure, but a doubt remains: how do I find the highest accel value that does not leads to skipped steps ? by trial and error only ?
Thank you again for helping.
That’s generally how it’s done yes.
