Smoothieboard repaired and ready to fire that 400W/48v spindle
As an idiot who has had some chillipeppr experience how does cncweb compare? +Peter van der Walt
CP does support CAM.
Supported File Types
CP LW
Brd
Font
SVG SVG
AI
DXF
Brd
Eagle Board Files used to cut Circuit boards on CNC
Font:) Direct font input
SVG:) Inkscape vector files
AI:) Adobe Illustrator vector files
DXF:) Autocad vector files
IMG:) Images for doing image rastering
In my opinion the advantage to using LaserWeb would be the Image rastering. Also LW has a wider selection of supported vector file formats.
CP is definitely better at managing machine connections. For example in your shop you could have a Laser and a CNC both connected to a Rasp Pi. Each Rasp Pi would have the port websocket service running. Now you can connect to any of these machines from CP, CP will automatically scan your local area network to find all web-services. I really like this separation between the port web socket and the actual UI it would be a nice enhancement for LW.
