I have had smoothieware running for a while now. I have 3 different hardware boards and they all do the same thing.
Works fine printing from SD Card.
I do run the Viki2 display
But if i am connected to it from the built in web browser, will randomly hangs.
If i have a octopi connected via the ethernet port it also hangs. I also have tried disabling the Webserver.
If i have astro print connected it via usb port it hangs.
Trying to copy a gcode file either by usb or ethernet port is very slow.
I have seen a number of other posts of people having hanging issues whist communicated through the webserver.
But as i mentioned i experienced hanging through USB Port as well.
Are these a issues still to be addressed?
Is the a cpu / hardware limitation?
Would like to so info on this either i know to wait and be patient, get different hardware, or wait for faster hardware.
or there is some setting i can change to address this.
