Smoothieware question: Got an azteeg x5 mini I’m setting up. Firmware and config file on 4gb micro sd, powered from usb - some light flashing happened then all solid green except play. Doesn’t show up as a device on 3 different windows machines I tried (com part or otherwise, drivers installed before plugging in.)
Does it only respond when it’s happy with all limit switches, thermistors, etc.? Or is something wrong here?
When I check the micro sd card contents, the firmware file extension is being changed to .CUR…
check you flashed a binary file and not the html, if the leds do not flash then the firmware was bad. Check the firmware md5sum with the on eon the github site. Once flashed the two leds should flash and two will be solid.
