I would like a function that will Pause the print, move Bed / Z axis away from extruder.
I should be able then to jog the extruder / bed anyware.
manually retract filament
install new filament, manually extrude/prime.
then be able to resume the print from where it left off.
This would also be handy for use with a filament detector.
At least this was if filament runs out it will pause in a safe location, maybe turn off heaters, and will not melt a hole in my print.
Is this possible to be looked at and done?
