So, a tiny update on printed diffs. In mid July I added 0.15mm stainless steel washers on the in and outside of the case where the outgoing axle is. That is four washers in total on each diff. And the result is that I haven’t broken a diff since. I’m very happy about that even though I must admit I’m a bit surprised.
Originally shared by Daniel Norée
Friction sucks or actually heat+friction sucks. The differential with printed parts only has worked pretty good so far but as other parts in the drivetrain have gotten more durable the more stress is put on the differential.
My biggest problem has been the Axle shafts “digging” in to the diff casing due to the heat and friction.
I don’t really want to incorporate “non-printed” or “non-standard” parts, but I have made some 0.15mm thick lasercut washers to put on the inside and outside as seen on the pictures. More testing to be done.
As a sidetrack I have started to design a new diff or rather new gears in the diff to even out the pressure of the gears. More on that later, first priority is to make this work somewhat ok.
