So after ditching the preconfigured Smartrap firmware I have switched over to the stock marlin. My problem is that for some reason I am getting a temperature reading of 22c when the hotend is at 0c. Anyone know what the issue could be?
I have the parameters for my jhead lite v2 set in configuration h but I am still getting a false reading.
The thermistors are set up to be more precise around their normal operating temperatures, and they may loose some precision around room temperature because they don’t need to know those temperatures precisely. 22C vs 16C sounds like a larger discrepancy than I would expect to see, but it may be correct. Make sure that your firmware is configured to use the thermistor you’re actually using, they’re not interchangeable.
