So here is the issue I am having now when heating the bed.
So here is the issue I am having now when heating the bed. The bed will get up to temp then suddenly I have stepper faults and everything shuts down. It doesn’t seem to matter if I am going to 35c or 100c, when it gets to temp everything crashes. Below is what I can get from the logs when this happens. I tried turning logging up to debug but the steppers just start vibrating when I turn everything on and I can’t ever access Octoprint, but I can SSH in.
WARNING Heater time update large: E temp: 30.265003748 time delta: 0.253293991089
WARNING Heater time update large: H temp: 0.0 time delta: 0.253234863281
WARNING Heater time update large: HBP temp: 32.9619144239 time delta: 0.505464792252
INFO End Stop Z2 hit!
ERROR Alarm: Stepper X
INFO End Stop Y2 hit!
INFO End Stop X2 hit!
INFO End Stop Z1 hit!
ERROR Alarm: Stepper E
ERROR Alarm: Stepper Z
ERROR Alarm: Stepper Y
What current are you setting your steppers to run at? Are there any radiators to cool them in place? Typically stepper driver alarms are due to the drivers overheating. I have a small fan blowing air across the top of my cape with heatsinks on each driver chip.
My current is set to 0.5 right now, but just in case I also set them to 0.1 and I get the same issue. I have a fan blowing across the steppers as well. The printer will print without the bed but that part seems to be the key to the issue. Could this be a bad power supply causing replicape to misinterpret the problem? It is a 500w single rail PC power supply but it might be bad.
That could be. If your bed is drawing too many amperes, the voltage to the steppers will drop. What PSU do you use?
That is a weird issue! The “delta time” for E means that redeem was not able to get temperatures for 30 seconds. I’ve seen this happen during start-up sometimes, but only with ~1 second. And the steppers are working fine without the heated bed? Can you post a picture of your board with connections?
Elias, I seem to remember someone else had a similar delta time issue because they were using a D1W thermal sensor, no?
I just realized I pulled the timing out of those log files so its impossible to see if the deltas are related to this issue. I will double check to see if they are related time wise. Without the heated bed I can print just fine for at least 30 minutes as thats the longest print I have had. I will grab a picture of the board this evening. And here is the PSU.
http://www.frys.com/product/6893426
It powered the bed fine under RAMPs but I realize that likely has little bearing now.
So I bought a MeanWell NES-350-12. Since my bed can’t run 24v this should do fine until I build the D-Bot I want and end up needing a new bed.
So the new PS runs the bed fine. I am not sure why the PSU did not have issues doing a bed PID tune, but caused a bunch of issues when reaching print temp regardless of actual set temp.
@James_Brassill that is interesting! I’d be interested in seeing the data for the actual PID tuning and I’ve thought of implementing a publishing function for it similar to the bed leveling algorithm, but I have not gotten around to it yet. If you have changed PSU, I won’t ask you for a screen dump though:)
I should still have the logs from the old PSU and can dig through them and find that data for the PID. I can also run one on the new PSU. I am thinking maybe holding it at temp caused some problem in the PSU and I had a current spike that caused replicape to shut down to protect itself. At this point I am just spit balling though.
