So I built my new geeetech g2s pro and I can control everything via repetier host except the sd card… Can’t upload/delete, start or stop an sd print from repetier host… Also, the printer doesn’t transmit info to repetier server, so I can’t do anything with my server. Any tips? Mostly want to get it to work with repetier server
Does the SDCARD work from the LCD panel?
Yes. I can use it via the printer directly but not through repetier host at all
Try uninstalling and then reinstall. This may solve it.
It works just fine with my other printer…
Repetier host will upload to the ad of my other printer. I’m just wondering if the firmware in the new one doesn’t support it
