So I finally got my inductive Z probe to work properly,
So I finally got my inductive Z probe to work properly, but I am now having problems getting the machine to stay within the build area it has at the moment.
If I move it around in software, it’s fine, it stays where it needs to be, and everything works as intended. If I run GCode, then things go wrong.
It does not want to print centered, (the print wants to print in the bottom right corner of the bed.) It seems to think that it has a larger print area then it actually does.
I think I may have missed some configuration, but the only thing I can find with some searching is that I need to edit the configuration.h for the firmware, but I can’t find an up to date source for the Printrbot firmware.
Also is there a way to configure this stuff with GCode commands?
Thanks for all the help.
The Printrbot support site should have the updated source files for all of their supported firmware variants.
@funinthefalls ​ Looked around, could not find any pages with the sources. Perhaps @Brook_Drumm ​ might know
@Lukas_Mathis Slicer and Repetier are both configured the same. I have messed around with the slicer settings and they don’t seem to want to change anything no matter how I configure it.
What model Printrbot is it?
