So I got my nozzle clogged. The Spitfire on Bukobot duo, .35mm nozzle size.
I tried a cold pull using T-Glase, it did clear it some but it is still partially clogged (after may attempts at doing a cold pull using the instructions from the wiki at http://bukobot.com/nozzle-cleaning). Now it spits out 2 beads of plastic, one “straight” and one all squigly, so I think the clog is in middle of it somehow.
Question I have, if the cold pull did not work all the way using t-glase, is there a chance it could still work if I purchased some nylon 216? Wondering if I should get some 216 or just get a new nozzle.
Also, I wonder if I actually deformed the tip, how easy (or hard) is it to accidentally deform a tip? I usually use wire cutter pliers to get the gunk off of the nozzle when it is hot but now I’m wondering if that was a bad idea ™? With how it does a “split stream” I wonder if I squeezed the tip closed in the middle somehow.
EDIT: Oh yeah, and since not much comes out, the drive gear skips when attempting to extrude.
Sounds like you at least have something in there that will need to be dislodged with a wire. I’ve never done cold pulls with PET, but it doesn’t seem like it would be particularly good for that purpose. ABS/PLA would probably be better, by Nylon 618 is king for that.
@Jonathan_Foote I usually pluck a bristle from a small wire brush, though I’ve also got some acupuncture needles on order that look like they might be ideal.
I tried this in the past with T-Glase and it didn’t work. However, the Taulman 618 did. You might want to retry with 618. The other thing I do is keep pushing the filament into the nozzle while it cools and once it sets, pull it (takes some pulling, but works really well) hope that helps.
