Hairspray not a good choice due to the solvents and the fact that it often ‘sets’. The solvents will make their way into components and affect their construction. Capacitors are the worst, it could take months before the effects start to be seen.
Silicon is a last resort because it can’t be removed again, not without introducing the solvent effect again.
Hellerine is vegetable based with anti mold and fungus additives and has been around for years and years. Well established product for lubrication in electronic assemblies, like sleeving. Does dissipate, so its not a long term lubricant. Unlike silicon, it can be removed.
@Robert_Atkins fishing them through is easy, but soon as the top part of the strip hits the acrylic, it sticks and is nearly impossible to just pull through after. I have to use shim to push in to separate it.
Wouldnt hairspray end up sticking afterwards?
I’ll be doing a lot of the physical build stuff this weekend, so I’ll take some pics/vid perhaps.
Yeah, it does end up sticking, but I generally don’t remove stuff once it’s in place, so it works for me. But I hadn’t really though of it as a solvent as Adam said, so I might do some tests
