So I just got my k40 in the mail,
So I just got my k40 in the mail, and it’s unboxed and sitting on my workbench. I’ve been reading posts on here, a similar facebook group, and watching unboxing videos since I put in the order. I know to make sure my water is cold, but not too cold, check for any air bubbles in the tube, aligns and clean the mirrors, make sure the fan and pump are running, check all the electrical connections, make sure my ground is good… Am I missing anything? Any gotchas I should know about?
Check for mirror alignment (I guess that is after you’ve got it up & running).
(edit) + link here http://dck40.blogspot.com.au/2013/02/post-by-nycon-how-to-adjust-mirrors-for.html
relax, put your goggles on , take a good breath, welcome among us and enjoy ;-))
PS: identify your components, electronic board, PSU, softwares, check wiring, take photos. try factory solution to have a reference comparison point. after few attempt you would like to think about how to make it better. (read my post next saturday)
So the water inlet and outlet on the tube should be facing up so that bubbles are easier to get out, right?
Also, do not set the power level too high,the lower amperage you can run at = the longer the tube will last.
It test fires, and I haven’t lit anything on fire, so I’m good. Thanks for the tips!
