So I narrowed down the source of my problem. It seems that whenever i have the LCD Panel (Viki 2) plugged into the board, it starts giving off the error. the instant I unplug it, the error stops. Any ideas what might be causing this?
Those drivers use SPI… so that might be conflicting.
Hmm. I’ll have to go through the config and see if there is a pin that is conflicting. Might try a different firmware as well just to make sure it’s not that either
Im not too familiar with the SPI drivers, but I cant find any conflicts with the pins. What else could be wrong?
Shield your cables to the panel and ground one end
@Douglas_Pearless Tried that. Doesnt seem to have made a difference.
OK, can you post your config
Robot module configurations : general handling of movement G-codes and slicing into moves
default_feed_rate 10000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 10000 # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment 0.5 # Arcs are cut into segments ( lines ), this is the length for these segments. Smaller values mean more resolution, higher values mean faster computation
#mm_per_line_segment 5 # Lines can be cut into segments ( not usefull with cartesian coordinates robots ).
Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
arm_solution corexy #sets the stepper motor movement configuration
alpha_steps_per_mm 533.33334 # Steps per mm for alpha stepper
beta_steps_per_mm 533.33334 # Steps per mm for beta stepper
gamma_steps_per_mm 960 # Steps per mm for gamma stepper
Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOUR ARE DOING
acceleration 1000 # Acceleration in mm/second/second.
z_acceleration 300 # Acceleration for Z only moves in mm/s^2, 0 disables it, disabled by default. DO NOT SET ON A DELTA
acceleration_ticks_per_second 1000 # Number of times per second the speed is updated
junction_deviation 0.05 # Similar to the old “max_jerk”, in millimeters, see : https://github.com/grbl/grbl/blob/master/planner.c#L409
# and Configuring Grbl v0.8 · grbl/grbl Wiki · GitHub . Lower values mean being more careful, higher values means being faster and have more jerk
Stepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
base_stepping_frequency 100000 # Base frequency for stepping
Stepper module pins ( ports, and pin numbers, appending “!” to the number will invert a pin )
alpha_step_pin 2.1 # Pin for alpha stepper step signal
alpha_dir_pin 0.11 # Pin for alpha stepper direction
alpha_en_pin nc # Pin for alpha enable pin 0.10
alpha_current 0.9 # X stepper motor current
x_axis_max_speed 12000 # mm/min
alpha_max_rate 12000.0 # mm/min actuator max speed
beta_step_pin 2.2 # Pin for beta stepper step signal
beta_dir_pin 0.20 # Pin for beta stepper direction
beta_en_pin nc # Pin for beta enable
beta_current 0.9 # Y stepper motor current
y_axis_max_speed 12000 # mm/min
beta_max_rate 12000.0 # mm/min actuator max speed
gamma_step_pin 2.3 # Pin for gamma stepper step signal
gamma_dir_pin 0.22! # Pin for gamma stepper direction
gamma_en_pin nc # Pin for gamma enable
gamma_current 0.9 # Z stepper motor current
z_axis_max_speed 1200 # mm/min
gamma_max_rate 1500.0 # mm/min actuator max speed
bigfoot settings
motor_driver_control.alpha.enable true # alpha (X) is a TMC26X
motor_driver_control.alpha.designator X # A to set the settings
motor_driver_control.alpha.chip TMC2660 # chip name
motor_driver_control.alpha.current 900 # current in milliamps
motor_driver_control.alpha.max_current 1000 # max current in milliamps
motor_driver_control.alpha.microsteps 128 # microsteps 256 max
motor_driver_control.alpha.alarm true # set to true means the error bits are checked
motor_driver_control.alpha.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.alpha.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.alpha.spi_cs_pin 0.10 # SPI CS pin
#motor_driver_control.alpha.spi_frequency 100000 # SPI frequency
motor_driver_control.alpha.sense_resistor 100 # set the sense resistor used.
motor_driver_control.beta.enable true # beta (Y) is a TMC26X
motor_driver_control.beta.designator Y # B to set the settings
motor_driver_control.beta.chip TMC2660 # chip name
motor_driver_control.beta.current 900 # current in milliamps
motor_driver_control.beta.max_current 1000 # max current in milliamps
motor_driver_control.beta.microsteps 128 # microsteps 256 max
motor_driver_control.beta.alarm true # set to true means the error bits are checked
motor_driver_control.beta.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.beta.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.beta.spi_cs_pin 0.19 # SPI CS pin DRV8711 requires inverted CS
#motor_driver_control.beta.spi_frequency 100000 # SPI frequency
motor_driver_control.beta.sense_resistor 100 # set the sense resistor used
motor_driver_control.gamma.enable true # gamma (Z) is a TMC26X
motor_driver_control.gamma.designator Z # G to set the settings
motor_driver_control.gamma.chip TMC2660 # chip name
motor_driver_control.gamma.current 800 # current in milliamps
motor_driver_control.gamma.max_current 1000 # max current in milliamps
motor_driver_control.gamma.microsteps 16 # microsteps 256 max
motor_driver_control.gamma.alarm true # set to true means the error bits are checked
motor_driver_control.gamma.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.gamma.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.gamma.spi_cs_pin 0.21 # SPI CS pin DRV8711 requires inverted CS
#motor_driver_control.gamma.spi_frequency 100000 # SPI frequency
motor_driver_control.gamma.sense_resistor 100 # set the sense resistor used
Serial communications configuration ( baud rate default to 9600 if undefined )
uart0.baud_rate 115200 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface and a terminal connected)
#msd_disable false # disable the MSD (USB SDCARD) when set to true
Extruder module configuration
extruder.hotend.enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend.steps_per_mm 476.5 # Steps per mm for extruder stepper
extruder.hotend.default_feed_rate 1200 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend.acceleration 500 # Acceleration for the stepper motor mm/sec²
extruder.hotend.max_speed 60 # mm/s
extruder.hotend.step_pin 2.0 # Pin for extruder step signal
extruder.hotend.dir_pin 0.5! # Pin for extruder dir signal
extruder.hotend.en_pin nc # Pin for extruder enable signal
extruder offset
extruder.hotend.x_offset 0 # x offset from origin in mm
extruder.hotend.y_offset 0 # y offset from origin in mm
extruder.hotend.z_offset 0 # z offset from origin in mm
firmware retract settings when using G10/G11, these are the defaults if not defined, must be defined for each extruder if not using the defaults
extruder.hotend.retract_length 3 # retract length in mm
extruder.hotend.retract_feedrate 45 # retract feedrate in mm/sec
extruder.hotend.retract_recover_length 0 # additional length for recover
extruder.hotend.retract_recover_feedrate 8 # recover feedrate in mm/sec (should be less than retract feedrate)
extruder.hotend.retract_zlift_length 0 # zlift on retract in mm, 0 disables
extruder.hotend.retract_zlift_feedrate 6000 # zlift feedrate in mm/min (Note mm/min NOT mm/sec)
delta_current 0.8 # Extruder stepper motor current
motor_driver_control.delta.enable true # delta (E1) is a TMC26X
motor_driver_control.delta.designator A # D to set the settings
motor_driver_control.delta.chip TMC2660 # chip name
motor_driver_control.delta.current 800 # current in milliamps
motor_driver_control.delta.max_current 1000 # max current in milliamps
motor_driver_control.delta.microsteps 16 # microsteps 256 max
#motor_driver_control.delta.decay_mode 1 # decay mode default
motor_driver_control.delta.alarm true # set to true means the error bits are checked
motor_driver_control.delta.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.delta.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.delta.spi_cs_pin 0.4 # SPI CS pin
#motor_driver_control.delta.spi_frequency 100000 # SPI frequency
motor_driver_control.delta.sense_resistor 100 # set the sense resistor used.
Second extruder module configuration
extruder.hotend2.enable false # Whether to activate the extruder module at all. All configuration is ignored if false
extruder.hotend2.steps_per_mm 476.5 # Steps per mm for extruder stepper
extruder.hotend2.default_feed_rate 1200 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder.hotend2.acceleration 1000 # Acceleration for the stepper motor, as of 0.6, arbitrary ratio
extruder.hotend2.max_speed 60 # mm/s
extruder.hotend2.step_pin 2.8 # Pin for extruder step signal
extruder.hotend2.dir_pin 2.13 # Pin for extruder dir signal
extruder.hotend2.en_pin nc # Pin for extruder enable signal
extruder.hotend2.x_offset 0 # x offset from origin in mm
extruder.hotend2.y_offset 25.0 # y offset from origin in mm
extruder.hotend2.z_offset 0 # z offset from origin in mm
epsilon_current 0.8 # Second extruder stepper motor current
motor_driver_control.epsilon.enable false # epsilon (E2) is a TMC26X
motor_driver_control.epsilon.designator B # E to set the settings
motor_driver_control.epsilon.chip TMC2660 # chip name
motor_driver_control.epsilon.current 800 # current in milliamps
motor_driver_control.epsilon.max_current 1000 # max current in milliamps
motor_driver_control.epsilon.microsteps 16 # microsteps 256 max
motor_driver_control.epsilon.alarm true # set to true means the error bits are checked
motor_driver_control.epsilon.halt_on_alarm false # if set to true means ON_HALT is entered on any error bits being set
motor_driver_control.epsilon.spi_channel 0 # SPI channel 1 is sdcard channel
motor_driver_control.epsilon.spi_cs_pin 4.29 # SPI CS pin DRV8711 requires inverted CS
#motor_driver_control.epsilon.spi_frequency 100000 # SPI frequency
motor_driver_control.epsilon.sense_resistor 100 # set the sense resistor used
Laser module configuration
laser_module_enable false # Whether to activate the laser module at all. All configuration is ignored if false.
#laser_module_pin 2.7 # this pin will be PWMed to control the laser
#laser_module_max_power 0.8 # this is the maximum duty cycle that will be applied to the laser
#laser_module_tickle_power 0.0 # this duty cycle will be used for travel moves to keep the laser active without actually burning
Hotend temperature control configuration
temperature_control.hotend.enable true # Whether to activate this ( “hotend” ) module at all. All configuration is ignored if false.
temperature_control.hotend.thermistor_pin 0.24 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.4 # Pin that controls the heater
temperature_control.hotend.thermistor EPCOS100K # see Temperaturecontrol | Smoothieware Documentation
#temperature_control.hotend.beta 4066 # or set the beta value
temperature_control.hotend.designator T0 #
#temperature_control.hotend.p_factor 13.7 #
#temperature_control.hotend.i_factor 0.097 #
#temperature_control.hotend.d_factor 24 #
#temperature_control.hotend.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
Hotend2 temperature control configuration
temperature_control.hotend2.enable false # Whether to activate this ( “hotend” ) module at all. All configuration is ignored if false.
temperature_control.hotend2.thermistor_pin 0.25 # Pin for the thermistor to read
temperature_control.hotend2.heater_pin 2.5 # Pin that controls the heater
temperature_control.hotend2.thermistor EPCOS100K # see Temperaturecontrol | Smoothieware Documentation
##temperature_control.hotend2.beta 4066 # or set the beta value
temperature_control.hotend2.set_m_code 104 #
temperature_control.hotend2.set_and_wait_m_code 109 #
temperature_control.hotend2.designator T1 #
#temperature_control.hotend2.p_factor 13.7 # permanently set the PID values after an auto pid
#temperature_control.hotend2.i_factor 0.097 #
#temperature_control.hotend2.d_factor 24 #
#temperature_control.hotend2.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
temperature_control.bed.enable true #
temperature_control.bed.bang_bang true # sets the temperature controller to not use PWM
temperature_control.bed.thermistor_pin 0.23 #
temperature_control.bed.heater_pin 2.7 #
temperature_control.bed.thermistor EPCOS100K # see Temperaturecontrol | Smoothieware Documentation
#temperature_control.bed.beta 4066 # or set the beta value
temperature_control.bed.set_m_code 140 #
temperature_control.bed.set_and_wait_m_code 190 #
temperature_control.bed.designator B #
#temperature_control.bed.max_pwm 64 # max pwm, 64 is a good value if driving a 12v resistor with 24v.
Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 0.26 #
switch.misc.enable true #
switch.misc.input_on_command M42 #
switch.misc.input_off_command M43 #
switch.misc.output_pin 1.22 #
automatically toggle a switch at a specified temperature. Different ones of these may be defined to monitor different temperatures and switch different swithxes
useful to turn on a fan or water pump to cool the hotend
temperatureswitch.hotend.enable true # Enables the hotend fan temperature switch
temperatureswitch.hotend.designator T0 # first character of the temperature control designator to use as the temperature sensor to monitor
temperatureswitch.hotend.switch misc # select which switch to use, matches the name of the defined switch
temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
temperatureswitch.hotend.heatup_poll 10 # poll heatup at 15 sec intervals
temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervals
temperatureswitch.hotend.designator T1 # first character of the temperature control designator to use as the temperature sensor to monitor
temperatureswitch.hotend.heatup_poll 10 # poll heatup at 10 sec intervals
filament out detector
#filament_detector.enable true #
#filament_detector.encoder_pin 0.26 # must be interrupt enabled pin (0.26, 0.27, 0.28)
#filament_detector.seconds_per_check 2 # may need to be longer
#filament_detector.pulses_per_mm 1.0 # will need to be tuned
#filament_detector.bulge_pin 0.27 # optional bulge detector switch and/or manual suspend
Switch module for spindle control
#switch.spindle.enable false #
Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
corexy_homing true # set to true if homing on a hbit or corexy
alpha_min_endstop 1.24^ # add a ! to invert if endstop is NO connected to ground
alpha_max_endstop 1.24^ # 1.27
alpha_homing_direction home_to_min # or set to home_to_max and set alpha_max
alpha_min 0 # this gets loaded after homing when home_to_min is set
alpha_max 355 # this gets loaded after homing when home_to_max is set
alpha_max_travel 356 #
beta_min_endstop 1.25^ #
beta_max_endstop 1.25^ # 1.28
beta_homing_direction home_to_min #
beta_min 0 #
beta_max 355 #
beta_max_travel 356 #
#gamma_min_endstop 1.29^ #
gamma_max_endstop 1.26^ #
gamma_homing_direction home_to_max #
gamma_min 0 #
gamma_max 405 #
gamma_max_travel 420 #
homing_order ZXY #
optional enable limit switches, actions will stop if any enabled limit switch is triggered
#alpha_limit_enable false # set to true to enable X min and max limit switches
#beta_limit_enable false # set to true to enable Y min and max limit switches
#gamma_limit_enable false # set to true to enable Z min and max limit switches
#probe endstop
#probe_pin 1.29 # optional pin for probe
alpha_fast_homing_rate_mm_s 50 # feedrates in mm/second
beta_fast_homing_rate_mm_s 50 # "
gamma_fast_homing_rate_mm_s 20 # "
alpha_slow_homing_rate_mm_s 10 # "
beta_slow_homing_rate_mm_s 10 # "
gamma_slow_homing_rate_mm_s 2 # "
alpha_homing_retract_mm 10 # distance in mm
beta_homing_retract_mm 15 # "
gamma_homing_retract_mm 1 # "
#endstop_debounce_count 100 # uncomment if you get noise on your endstops, default is 100
endstop_debounce_ms 5 #
optional Z probe
zprobe.enable false # set to true to enable a zprobe
zprobe.probe_pin 1.29!^ # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 5 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 100 # move feedrate mm/sec
zprobe.probe_height 5 # how much above bed to start probe
associated with zprobe the leveling strategy to use
#leveling-strategy.three-point-leveling.enable true # a leveling strategy that probes three points to define a plane and keeps the Z parallel to that plane
#leveling-strategy.three-point-leveling.point1 100.0,0.0 # the first probe point (x,y) optional may be defined with M557
#leveling-strategy.three-point-leveling.point2 200.0,200.0 # the second probe point (x,y)
#leveling-strategy.three-point-leveling.point3 0.0,200.0 # the third probe point (x,y)
#leveling-strategy.three-point-leveling.home_first true # home the XY axis before probing
#leveling-strategy.three-point-leveling.tolerance 0.03 # the probe tolerance in mm, anything less that this will be ignored, default is 0.03mm
#leveling-strategy.three-point-leveling.probe_offsets 0,0,0 # the probe offsets from nozzle, must be x,y,z, default is no offset
#leveling-strategy.three-point-leveling.save_plane false # set to true to allow the bed plane to be saved with M500 default is false
kill button (used to be called pause) maybe assigned to a different pin, set to the onboard pin by default
kill_button_enable true # set to true to enable a kill button
kill_button_pin 2.12 # kill button pin.
Panel See Using Panel controllers with Smoothieboard | Smoothieware Documentation
panel.enable true # set to true to enable the panel code
Example viki2 config for an azteeg miniV2 with IDC cable
panel.lcd viki2 # set type of panel
panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
panel.spi_cs_pin 0.16 # set spi chip select
panel.encoder_a_pin 3.26!^ # encoder pin
panel.encoder_b_pin 3.25!^ # encoder pin
panel.click_button_pin 2.11!^ # click button
panel.a0_pin 2.6 # st7565 needs an a0
panel.contrast 6 # override contrast setting (default is 9)
panel.encoder_resolution 4 # override number of clicks to move 1 item (default is 4)
#panel.button_pause_pin 1.30^ # kill/pause set one of these for the auxilliary button on viki2
#panel.back_button_pin 1.22!^ # back button recommended to use this on EXP1
#panel.buzz_pin 1.31 # pin for buzzer on EXP2
#panel.red_led_pin 1.19 # pin for red led on viki2 on EXP1
#panel.blue_led_pin 1.20 # pin for blue led on viki2 on EXP1
panel.external_sd true # set to true if there is an extrernal sdcard on the panel
panel.external_sd.spi_channel 0 # set spi channel the sdcard is on
panel.external_sd.spi_cs_pin 1.21 # set spi chip select for the sdcard
panel.external_sd.sdcd_pin 1.18!^ # sd detect signal (set to nc if no sdcard detect) 1.18
panel.menu_offset 1 # some panels will need 1 here
Example miniviki2 config
#panel.lcd mini_viki2 # set type of panel
#panel.spi_channel 0 # set spi channel to use P0_18,P0_15 MOSI,SCLK
#panel.spi_cs_pin 0.16 # set spi chip select
#panel.encoder_a_pin 3.25!^ # encoder pin
#panel.encoder_b_pin 3.26!^ # encoder pin
#panel.click_button_pin 2.11!^ # click button
#panel.a0_pin 2.6 # st7565 needs an a0
##panel.contrast 18 # override contrast setting (default is 18)
##panel.encoder_resolution 2 # override number of clicks to move 1 item (default is 2)
#panel.menu_offset 1 # here controls how sensitive the menu is. some panels will need 1
panel.gamma_jog_feedrate 200 # z jogging feedrate in mm/min
panel.hotend_temperature 185 # temp to set hotend when preheat is selected
panel.T1_temperature 185 # temp to set hotend when preheat is selected
panel.bed_temperature 60 # temp to set bed when preheat is selected
network settings
network.enable false # enable the ethernet network services
network.webserver.enable true # enable the webserver
network.telnet.enable true # enable the telnet server
network.plan9.enable true # enable the plan9 network filesystem
network.ip_address 192.168.7.100 # the IP address
network.ip_mask 255.255.255.0 # the ip mask
network.ip_gateway 192.168.7.254 # the gateway address
Example of a custom menu entry, which will show up in the Custom entry.
NOTE _ gets converted to space in the menu and commands, | is used to separate multiple commands
custom_menu.fan_on.enable true #
http://custom_menu.fan_on.name Fan_On #
custom_menu.fan_on.command M106_S255 #
custom_menu.fan_off.enable true #
http://custom_menu.fan_off.name Fan_Off #
custom_menu.fan_off.command M107 #
custom_menu.center_extruder.enable true #
http://custom_menu.center_extruder.name Center_Extruder #
custom_menu.center_extruder.command G0_X177_Y174 #
custom_menu.raise_bed.enable true #
http://custom_menu.raise_bed.name Bed_To_Nozzle_10mm #
custom_menu.raise_bed.command G0_Z10 #
custom_menu.z_offset.enable true #
http://custom_menu.z_offset.name Set_Bed_Offset #
custom_menu.z_offset.command M306_Z0 #
custom_menu.save_settings.enable true #
http://custom_menu.save_settings.name Save_Settings #
custom_menu.save_settings.command M500 #
Azteeg specific settings do not change
currentcontrol_module_enable false #
digipot_max_current 2.4 # max current
digipot_factor 103.0 # factor for converting current to digipot value
#51.0 for SD8825, SD6128, BSD4989
leds_disable true # disable using leds after config loaded
