So I want to add duel extrusion to my printer.
So I want to add duel extrusion to my printer. but I bought the 4x Smoothieboard last year.
what do I need to upgrade to get to a 5x Smoothieboard?
And How?
You simply need to populate the parts for the fifth stepper, check out the BOM here https://docs.google.com/spreadsheets/d/1vshB97WWt6Lceo59aggbdhRuXxTEhSL9lkotScR0oYE/edit#gid=0 and look for “Stepper motor driver 5”
@Douglas_Pearless ​ Thanks!
Doug is spot on. Hope you’re ready to do some reflowin!
It can be simpler than that if you want, check out the docs for adding external drivers. Only need to wire in 4 pins instead of doing smd work
Yep, that is also true!
+Chris Chatelain +Douglas Pearless Thanks for the comments. I will look into external drives.
@jacob_keller you only need to add one external stepper driver, for example a TB6600
Thanks @Arthur_Wolf
