So I'm having difficulties connecting to the /dev/octoprint_1 because it only shows AUTO in
So I’m having difficulties connecting to the /dev/octoprint_1 because it only shows AUTO in the serial port option. I’ve tried reinstalling kamikaze and still nothing. The plugin redeem log reads as follows:
2016-10-17 18:34:49,887 root INFO Stepper watchdog started, timeout 500 s
2016-10-17 18:34:49,892 root WARNING USB gadget serial not available as /dev/ttyGS0
2016-10-17 18:34:49,896 root INFO Ethernet bound to port 50000
2016-10-17 18:34:50,074 root INFO Pipe octoprint open. Use ‘/dev/octoprint_1’ to communicate with it
2016-10-17 18:34:50,234 root INFO Pipe toggle open. Use ‘/dev/toggle_1’ to communicate with it
2016-10-17 18:34:50,394 root INFO Pipe testing open. Use ‘/dev/testing_1’ to communicate with it
2016-10-17 18:34:50,564 root INFO Pipe testing_noret open. Use ‘/dev/testing_noret_1’ to communicate with it
2016-10-17 18:34:50,588 root INFO Alarm: Operational
2016-10-17 18:34:50,596 root INFO Watchdog started, refresh 30 s
2016-10-17 18:34:50,600 root INFO Redeem ready
2016-10-17 18:36:26,592 root INFO – Logfile configured –
2016-10-17 18:36:27,233 root INFO Found Replicape rev. 0B3A
2016-10-17 18:36:27,431 root INFO End Stop Y2 hit!
2016-10-17 18:36:28,336 root INFO Stepper watchdog started, timeout 500 s
2016-10-17 18:36:28,350 root WARNING USB gadget serial not available as /dev/ttyGS0
2016-10-17 18:36:28,355 root INFO Ethernet bound to port 50000
2016-10-17 18:36:28,571 root INFO Pipe octoprint open. Use ‘/dev/octoprint_1’ to communicate with it
2016-10-17 18:36:28,774 root INFO Pipe toggle open. Use ‘/dev/toggle_1’ to communicate with it
2016-10-17 18:36:28,995 root INFO Pipe testing open. Use ‘/dev/testing_1’ to communicate with it
2016-10-17 18:36:29,193 root INFO Pipe testing_noret open. Use ‘/dev/testing_noret_1’ to communicate with it
2016-10-17 18:36:29,214 root INFO Alarm: Operational
2016-10-17 18:36:29,243 root INFO Watchdog started, refresh 30 s
2016-10-17 18:36:29,248 root INFO Redeem ready
2016-10-17 18:45:08,257 root INFO – Logfile configured –
2016-10-17 18:45:08,883 root INFO Found Replicape rev. 0B3A
2016-10-17 18:45:09,085 root INFO End Stop Y2 hit!
2016-10-17 18:45:09,947 root INFO Stepper watchdog started, timeout 500 s
2016-10-17 18:45:09,963 root WARNING USB gadget serial not available as /dev/ttyGS0
2016-10-17 18:45:09,970 root INFO Ethernet bound to port 50000
2016-10-17 18:45:10,178 root INFO Pipe octoprint open. Use ‘/dev/octoprint_1’ to communicate with it
2016-10-17 18:45:10,400 root INFO Pipe toggle open. Use ‘/dev/toggle_1’ to communicate with it
2016-10-17 18:45:10,592 root INFO Pipe testing open. Use ‘/dev/testing_1’ to communicate with it
2016-10-17 18:45:10,779 root INFO Pipe testing_noret open. Use ‘/dev/testing_noret_1’ to communicate with it
2016-10-17 18:45:10,822 root INFO Alarm: Operational
2016-10-17 18:45:10,845 root INFO Watchdog started, refresh 30 s
2016-10-17 18:45:10,864 root INFO Redeem ready
Please help!
It looks like redeem isn’t started ever… Look at the date of the log, that’s left over from the image creation. Can you try looking at the output of “systemctl status redeem -l -n 100”?
@Nathan_Reichenberger lastest version of redeem in the master or develop branches? If develop it won’t start because it’s missing one of the new library dependencies… you can fix it by running “pip install sympy” first.
How do I give it terminal commands if I can’t get to a terminal window via BBB? I’ve got a Mac, so is there any way I can control it via the terminal window on my Mac?
Uh, yes, sorry I forget to say it nowadays - usually we remote-login with SSH. Instructions and login info are here: http://wiki.thing-printer.com/index.php?title=Redeem#Troubleshooting
Awesome! Thank you! Just tagging onto my comment about changing the code for the screen, would I use the same method?
Yep! Pretty much all interactions go through SSH or Octoprint’s web UI, I think I’ve never actually connected a keyboard to my BBBs (and I build the Kamikaze/Umikaze images :wink: )
root@kamikaze:~# systemctl status redeem -l -n 100
● redeem.service - The Replicape Daemon
Loaded: loaded (/lib/systemd/system/redeem.service; enabled; vendor preset: enabled)
Active: inactive (dead)
Aug 22 01:00:41 kamikaze systemd[1]: Dependency failed for The Replicape Daemon.
Aug 22 01:00:41 kamikaze systemd[1]: redeem.service: Job redeem.service/start failed with result ‘dependency’.
So it looks like you were correct that redeeem didn’t even start. I ran “pip install sympy” which installed version 8.1.2 and then upgraded it to version 9.0.1 and both showed the same message as shown above. Where would I start to try and find/fix the problem?
● redeem.service - The Replicape Dameon
Active: failed (Result: exit-code) since Tue 2017-08-22 02:48:14 UTC; 1min 10s ago
Process: 1238 ExecStart=/usr/bin/redeem (code=exited, status=1/FAILURE)
Main PID: 1238 (code=exited, status=1/FAILURE)
Aug 22 02:48:10 kamikaze systemd[1]: Started The Replicape Dameon.
Aug 22 02:48:14 kamikaze redeem[1238]: Traceback (most recent call last):
Aug 22 02:48:14 kamikaze redeem[1238]: File “/usr/bin/redeem”, line 9, in
Aug 22 02:48:14 kamikaze redeem[1238]: load_entry_point(‘Redeem==1.2.2’, ‘console_scripts’, ‘redeem’)()
Aug 22 02:48:14 kamikaze redeem[1238]: File “/usr/lib/python2.7/dist-packages/pkg_resources/init.py”, line 567, in load_entry_point
Aug 22 02:48:14 kamikaze redeem[1238]: return get_distribution(dist).load_entry_point(group, name)
Aug 22 02:48:14 kamikaze redeem[1238]: File “/usr/lib/python2.7/dist-packages/pkg_resources/init.py”, line 2604, in load_entry_point
Aug 22 02:48:14 kamikaze redeem[1238]: return ep.load()
Aug 22 02:48:14 kamikaze redeem[1238]: File “/usr/lib/python2.7/dist-packages/pkg_resources/init.py”, line 2264, in load
Aug 22 02:48:14 kamikaze redeem[1238]: return self.resolve()
Aug 22 02:48:14 kamikaze redeem[1238]: File “/usr/lib/python2.7/dist-packages/pkg_resources/init.py”, line 2270, in resolve
Aug 22 02:48:14 kamikaze redeem[1238]: module = import(self.module_name, fromlist=[‘name’], level=0)
Aug 22 02:48:14 kamikaze redeem[1238]: File “/usr/lib/python2.7/dist-packages/redeem/Redeem.py”, line 40, in
Aug 22 02:48:14 kamikaze redeem[1238]: from Stepper import *
Aug 22 02:48:14 kamikaze redeem[1238]: File “/usr/lib/python2.7/dist-packages/redeem/Stepper.py”, line 28, in
Aug 22 02:48:14 kamikaze redeem[1238]: from ShiftRegister import ShiftRegister
Aug 22 02:48:14 kamikaze redeem[1238]: File “/usr/lib/python2.7/dist-packages/redeem/ShiftRegister.py”, line 40, in
Aug 22 02:48:14 kamikaze redeem[1238]: spi.bpw = 8
Aug 22 02:48:14 kamikaze redeem[1238]: AttributeError: ‘NoneType’ object has no attribute ‘bpw’
Aug 22 02:48:14 kamikaze systemd[1]: redeem.service: Main process exited, code=exited, status=1/FAILURE
Aug 22 02:48:14 kamikaze systemd[1]: redeem.service: Unit entered failed state.
Aug 22 02:48:14 kamikaze systemd[1]: redeem.service: Failed with result ‘exit-code’.
after trying to manually install the package feed twice, this is now what is happening
Uh which package? The Debian package is completely outdated, redeem is install from git directly, with the sources in /use/src/redeem.
Can you clarify which version of the image you’re installing and on what type of beagle one (black Ethernet or black wireless?)
Wait, when downloading the ~1GB size kamikaze image on the microSD card does that have the version of linux I need? Or do I need to install something onto the BBB before doing the kamikaze flash? The BBB I’m using is the Ethernet version, should I be using the wireless version?
I flashed the Kamikaze-2.0.8-2016-10-17.img.xz file onto my BBB
