So Im just about to do the firmware for the frankenbot and then it is ready to print. The thing is that I want to use the inductive sensor for autoleveling. I have a piece of glass with two strips of aluminum on the edges that I intended to level and home with. The sensor picks up the strips without an issue, but the problem is that when I run G28, the probe wnats to go to the center of the bed, where there is no aluminum and I can’t add it. Is there a way in which I can change the z zero x and y position to zero z on the edge of the bed??
Running Marlin on Printrboard Rev. F5 and slicing with Cura
