So I’m thinking my post from last night went into lala-land, and I suspect it’s something I did. Anyway, let’t try it again.
I tried installing LW3 on my Windows 10 Ultimate last night and ran into a few snags before I was able to get it to work.
First I tried the npm method to install everything. This fails on my system, it can’t find the package.json file at the end. I suspect it’s because my path has spaces and a period in it however I did not test this further.
I rolled back (deleted everything) and manually pulled it with git. Then ran npm install which run successfully … except, it installs an older version of serialport right off the bat. So I had to manually run ‘npm install serialport’ for it to upgrade it to the required 4.0.6 version. Once that was done, I was able to run node and load up the interface in a browser.
All in all, it’s nothing too terribly bad. Why the initial install drops an older version of serialport is something to look into, but it’s not a show stopper by any means.
I did not try the wrapped .exe file … I’m old, I’m hardcode unix, give me command line … none of the fancy stuff.
