So I've been having an issue with non cut moving speeds within laser web
So I’ve been having an issue with non cut moving speeds within laser web and I think I’ve narrowed it down to a sequence of events that trigger it. Anytime I run a job then adjust the z and reset it to 0 (just the z) to do another job, non cut speeds slow to the same rate that the job is defined. Anyone else been experiencing this?
I’ve seen the behavior you describe, but not often enough to want to troubleshoot it…
For me it’s every time I do that particular sequence. It’s not terrible. Just annoying.
