So last night I was experimenting with my apa102 strip, and according to the multimeter, the data and clock receive no power on the strip. However the chip is pushing out voltage. Are these strips sometimes low quality and have bad connection?
Also, at first, the strip would blink slightly when I’d upload onto my attiny, and then just hold random color on very very low output on random leds.
After a while I lowered the strip to a set of ten, and nothing.
I can get the leds to light up on a single apa102 when I run power and scrape contacts a little (wanted to see if it worked at all). And it flickers.
Originally, sometimes one led would turn white even though I was running the basic usage code for turning on red.
BTW, sorry, this might be out of order. I stayed up all night trying to get the programmer to have permission and a correct rule in ubuntu, then learning the code, then multimeter in everything, so I am definitely lacking some brain power.
Anyone have any insight?
Thanks
I am powering from usb, but it seemed as if the voltage was 5 on every led. I checked each led. It was previously lighting up slightly, but now nothing. voltage seems stable. do you think i should try with a high amp usb battery pack?
i set up my data and clock pin correctly (even used the data and clock pin according to the attiny pin guide)
running from the pinouts on the programmer that it has to test. after lots of trial and error, the strip would flash and flicker through colors then stop on low low power red. randomly sometimes it would show 1 led bright white.
