So one of the things I discovered is that if I use LaserDRW to draw lines, it only cuts once. So while I can’t draw things like living hinges in Illustrator, export as an image, and have it cut once, I can do the lines in LaserDRW and it would work just fine. Now I just need to find a work flow that actually produces a good result. On to exploring.
Huh, I will try that then. Thanks for the heads up. That would make my workflow a lot easier.
That didn’t work … was worth a try though.
