So the first print ran and failed, the off to Maker Faire Orlando for my first prints. Talk about cutting it close.
What build plate are you using there?
Could be white PEI?
@Helmi after seeing the delta printer work on clear acrylic I dropped this onto the bed to test with some place. It is 1/8 inch white cell cast acrylic lightly sanded with 320 grit sandpaper. Sticks amazingly well.
