So this will seem like a silly question to some but here goes…
I’ve noticed some machines mention they can be either 110 or 220 volts.
I’d prefer the 110 volts.
@Derek_Schuetz posted a link to this machine and I think I’ll get a quicker response from here then the ebayer.
Is this 110v?
Is it worth the extra money to save the time of having to do the upgrades?
Any help appreciated.
http://www.ebay.com/itm/152109833330
I would assume that this is 110v because it’s on the US. So if you are in the states that would be wise choice.
@Ariel_Yahni_UniKpty
Thanks.
Is the system worth the extra money?
@Nigel_Conroy it’s all about the budget you have and what you plan/need to cut. Most people buy the entry level 3020 size machine because of budget or need but mostly budget. I don’t know anyone that would not want a bigger more powerful tube. Also it seems this models come with the rotary, motorized bed level all very good added values. In the end if you can afford it, go for it. Unless someone has / knows another better priced machine
I got approved to spend between $1000-$1500 for school classroom. My thought is this will save me a load of time during my summer holidays setting one up. Which I can spend learning how to use it.
On closer inspection of one of the images it has a sticker with 110 Volt on one side and 220 Volts on each side…
It should be configured for the US my. guess is the seller is just using some stock photos
Thanks, I’ve ordered one identical that states its 110v.
Make sure there identical some sellers sell old models that one I linked had the motorized. Bed and was the best bang for the buck
I thought all power supplies had a switch for selecting between 110 (US) or 220 (EU).
I believe the 50W lasers I have looked at were all in the 1.5k range. While you wouldn’t need to modify the case for a more powerful laser as with a K40 and the larger cutting area is ideal (I would want to cut 12x12 inch sheets myself), you would still eventually want the upgrades offered by air assist, mirrors (?), and smoothie board controller.
If an 8x12 inch cutting area will work for your projects, and you plan to engrave or only cut thin (3mm) sheets, I would suggest buying two or three of the second gen laser cutters and upgrading them yourself over the summer so you are familiar with how they work. You should then always have a spare should one break.
@John-Paul_Hopman the upgraded for the 1500 is well worth it…air assist motor z table much larger cut volume print from USB stick lighting laser alignment emergency stop button independent power supplies and better electronics
Here is a link to the one I purchased
http://www.ebay.com/itm/391317039073
So that is an older model with manual tablw
@Derek_Schuetz the one you posted has a manual table. Does that mean this doesn’t have the updated electronics etc…?
It did say it was an updated version
Laser Engraver finally arrived. It’s a lot bigger and heavier than I thought!!!
How do I tell if it has the most up to date board, etc…?
It does have a motorized, with an up and down button on the side.
